[PATCH 10/12] satcan.c: Fix Unsigned compared against 0 (CID #1399768)
Ryan Long thisisryanlong at gmail.com
Thu Mar 4 19:50:23 UTC 2021
CID 1399768: Unsigned compared against 0 in satcan_ioctl().
Closes #4294
 bsps/shared/grlib/can/satcan.c | 16 ++++------------
 1 file changed, 4 insertions(+), 12 deletions(-)
diff --git a/bsps/shared/grlib/can/satcan.c b/bsps/shared/grlib/can/satcan.c
index c3fdc15..52e674c 100644
--- a/bsps/shared/grlib/can/satcan.c
+++ b/bsps/shared/grlib/can/satcan.c
@@ -239,9 +239,7 @@ static rtems_device_driver satcan_ioctl(rtems_device_major_number major, rtems_d
 		/* Get regmod structure from argument */
 		regmod = (satcan_regmod*)ioarg->buffer;
 		DBG("SatCAN: ioctl: getting register %d\n\r", regmod->reg);
-		if (regmod->reg < 0)
-			return RTEMS_INVALID_NAME;
-		else if (regmod->reg <= SATCAN_FILTER_STOP)
+		if (regmod->reg <= SATCAN_FILTER_STOP)
 			regmod->val = regs->satcan[regmod->reg];
 		else if (regmod->reg == SATCAN_WCTRL)
 			regmod->val = regs->ctrl;
@@ -260,9 +258,7 @@ static rtems_device_driver satcan_ioctl(rtems_device_major_number major, rtems_d
 		DBG("SatCAN: ioctl: setting register %d, value %x\n\r",
 		    regmod->reg, regmod->val);
 			regs->satcan[regmod->reg] = regmod->val;
 			regs->ctrl = regmod->val;
@@ -281,9 +277,7 @@ static rtems_device_driver satcan_ioctl(rtems_device_major_number major, rtems_d
 		DBG("SatCAN: ioctl: or:ing register %d, with value %x\n\r",
 			regs->satcan[regmod->reg] |= regmod->val;
 			regs->ctrl |= regmod->val;
@@ -302,9 +296,7 @@ static rtems_device_driver satcan_ioctl(rtems_device_major_number major, rtems_d
 		DBG("SatCAN: ioctl: masking register %d, with value %x\n\r",
 			regs->satcan[regmod->reg] &= regmod->val;
 			regs->ctrl &= regmod->val;
1.8.3.1
