[PATCH 11/12] b1553brm.c: Fix Unsigned compared against 0 (CID #1399773)
Ryan Long
thisisryanlong at gmail.com
Thu Mar 4 19:50:24 UTC 2021
CID 1399773: Unsigned compared against 0 in brm_write().
Closes #4295
bsps/shared/grlib/1553/b1553brm.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/bsps/shared/grlib/1553/b1553brm.c b/bsps/shared/grlib/1553/b1553brm.c
index 694f585..484ee6d 100644
--- a/bsps/shared/grlib/1553/b1553brm.c
+++ b/bsps/shared/grlib/1553/b1553brm.c
@@ -982,7 +982,7 @@ static rtems_device_driver brm_write(rtems_device_major_number major, rtems_devi
rw_args->bytes_moved = count;
- if (count >= 0) {
+ if (count > 0) {
return RTEMS_SUCCESSFUL;
return RTEMS_UNSATISFIED;
1.8.3.1
