[PATCH v1 2/7] score/aarch64: Fix interrupt level reads
Kinsey Moore
kinsey.moore at oarcorp.com
Thu Mar 4 22:15:38 UTC 2021
cpukit/score/cpu/aarch64/cpu.c | 2 +-
cpukit/score/cpu/aarch64/include/rtems/score/cpu.h | 8 ++++++--
2 files changed, 7 insertions(+), 3 deletions(-)
diff --git a/cpukit/score/cpu/aarch64/cpu.c b/cpukit/score/cpu/aarch64/cpu.c
index b977875fc3..75b1125cf7 100644
--- a/cpukit/score/cpu/aarch64/cpu.c
+++ b/cpukit/score/cpu/aarch64/cpu.c
@@ -166,7 +166,7 @@ uint64_t _CPU_ISR_Get_level( void )
: [level] "=&r" (level)
- return level & AARCH64_PSTATE_I;
+ return ( level & AARCH64_PSTATE_I ) != 0;
void _CPU_ISR_install_vector(
diff --git a/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h b/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
index 380d1380fb..ceb831a43f 100644
--- a/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
@@ -215,10 +215,14 @@ void AArch64_interrupt_flash( uint64_t level );
#else
static inline uint64_t AArch64_interrupt_disable( void )
- uint64_t level = _CPU_ISR_Get_level();
+ uint64_t level;
__asm__ volatile (
+ "mrs %[level], DAIF\n"
"msr DAIFSet, #0x2\n"
+ : [level] "=&r" (level)
return level;
@@ -250,7 +254,7 @@ static inline void AArch64_interrupt_flash( uint64_t level )
RTEMS_INLINE_ROUTINE bool _CPU_ISR_Is_enabled( uint64_t level )
- return ( level & AARCH64_PSTATE_I ) == 0;
+ return level == 0;
void _CPU_Context_Initialize(
2.20.1
