[PATCH v1 5/7] bsps/aarch64: RTEMS_DEBUG stack alignment faults
Kinsey Moore
kinsey.moore at oarcorp.com
Thu Mar 4 22:15:41 UTC 2021
Run with stack alignment faults enabled under RTEMS_DEBUG to catch any
stack misalignments early. This makes it easier to track them down
should they ever occur.
bsps/aarch64/shared/start/start.S | 8 ++++++++
cpukit/score/cpu/aarch64/aarch64-exception-default.S | 10 ++++++++--
2 files changed, 16 insertions(+), 2 deletions(-)
diff --git a/bsps/aarch64/shared/start/start.S b/bsps/aarch64/shared/start/start.S
index f4c62b2b6c..e4dd3c2cee 100644
--- a/bsps/aarch64/shared/start/start.S
+++ b/bsps/aarch64/shared/start/start.S
@@ -90,6 +90,14 @@ _start:
#endif
#endif
+ /* Initialize SCTLR_EL1 */
+ mov x0, XZR
+#if defined(RTEMS_DEBUG)
+ /* Enable Stack alignment checking */
+ orr x0, x0, #(1<<3)
+#endif
+ msr SCTLR_EL1, x0
#ifdef RTEMS_SMP
/* Read MPIDR and get current processor index */
mrs x7, mpidr_el1
diff --git a/cpukit/score/cpu/aarch64/aarch64-exception-default.S b/cpukit/score/cpu/aarch64/aarch64-exception-default.S
index 970ccf735f..d139fdc6a4 100644
--- a/cpukit/score/cpu/aarch64/aarch64-exception-default.S
+++ b/cpukit/score/cpu/aarch64/aarch64-exception-default.S
@@ -76,7 +76,7 @@
* TODO(kmoore) The current implementation here assumes that SP is not
* misaligned.
- .macro JUMP_HANDLER
+ .macro JUMP_HANDLER_SHORT
/* Mask to use in BIC, lower 7 bits */
mov x0, #0x7f
/* LR contains PC, mask off to the base of the current vector */
@@ -113,6 +113,10 @@
nop
nop
nop
+ .endm
+ JUMP_HANDLER_SHORT
nop
.endm
@@ -182,10 +186,12 @@ curr_el_sp0_serror_get_pc: /* The current PC is now in LR */
* the current SP.
curr_el_spx_sync:
+ msr SCTLR_EL1, XZR
stp x0, lr, [sp, #-0x10]! /* Push x0,lr on to the stack */
bl curr_el_spx_sync_get_pc /* Get current execution address */
curr_el_spx_sync_get_pc: /* The current PC is now in LR */
- JUMP_HANDLER
+/* Use short jump handler since this has an extra instruction to clear SCTLR */
JUMP_TARGET_SPx
.balign 0x80
2.20.1
