[PATCH 10/12] satcan.c: Fix Unsigned compared against 0 (CID #1399768)
Joel Sherrill
joel at rtems.org
Fri Mar 5 15:12:49 UTC 2021
On Fri, Mar 5, 2021, 9:08 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Thu, Mar 4, 2021 at 12:50 PM Ryan Long <thisisryanlong at gmail.com>
> wrote:
> > CID 1399768: Unsigned compared against 0 in satcan_ioctl().
> > Closes #4294
> > bsps/shared/grlib/can/satcan.c | 16 ++++------------
> > 1 file changed, 4 insertions(+), 12 deletions(-)
> > diff --git a/bsps/shared/grlib/can/satcan.c
> b/bsps/shared/grlib/can/satcan.c
> > index c3fdc15..52e674c 100644
> > --- a/bsps/shared/grlib/can/satcan.c
> > +++ b/bsps/shared/grlib/can/satcan.c
> > @@ -239,9 +239,7 @@ static rtems_device_driver
> satcan_ioctl(rtems_device_major_number major, rtems_d
> > /* Get regmod structure from argument */
> > regmod = (satcan_regmod*)ioarg->buffer;
> > DBG("SatCAN: ioctl: getting register %d\n\r",
> regmod->reg);
> should these DBG prints also be changed to %u?
Probably. Can this be put on his todo list? Enable the debug prints in
grlib and see what printf format specifier warnings come out?
This would seem to be the most reliable way to catch them all.
> > - if (regmod->reg < 0)
> > - return RTEMS_INVALID_NAME;
> > - else if (regmod->reg <= SATCAN_FILTER_STOP)
> > + if (regmod->reg <= SATCAN_FILTER_STOP)
> > regmod->val = regs->satcan[regmod->reg];
> > else if (regmod->reg == SATCAN_WCTRL)
> > regmod->val = regs->ctrl;
> > @@ -260,9 +258,7 @@ static rtems_device_driver
> > DBG("SatCAN: ioctl: setting register %d, value %x\n\r",
> > regmod->reg, regmod->val);
> > regs->satcan[regmod->reg] = regmod->val;
> > regs->ctrl = regmod->val;
> > @@ -281,9 +277,7 @@ static rtems_device_driver
> > DBG("SatCAN: ioctl: or:ing register %d, with value
> %x\n\r",
> > regs->satcan[regmod->reg] |= regmod->val;
> > regs->ctrl |= regmod->val;
> > @@ -302,9 +296,7 @@ static rtems_device_driver
> > DBG("SatCAN: ioctl: masking register %d, with value
> %x\n\r",
> > regs->satcan[regmod->reg] &= regmod->val;
> > regs->ctrl &= regmod->val;
> > 1.8.3.1
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210305/5a267258/attachment-0001.html>
