[PATCH v4 0/3] Add cadence-SPI driver
Jan.Sommer at dlr.de Jan.Sommer at dlr.de
Fri Mar 5 17:31:15 UTC 2021
Thanks, I got some test feedback from Rick van der Wal.
I will prepare a new patch set with some modifications.
The zynq-uart issue is currently more pressing for me.
Best regards,
   Jan
> -----Original Message-----
> From: Gedare Bloom <gedare at rtems.org>
> Sent: Friday, March 5, 2021 4:41 PM
> To: Sommer, Jan <Jan.Sommer at dlr.de>
> Cc: devel at rtems.org
> Subject: Re: [PATCH v4 0/3] Add cadence-SPI driver
> Jan, I think this driver is fine to go in if you're happy with it.
> On Fri, Feb 19, 2021 at 6:06 AM Jan Sommer <jan.sommer at dlr.de> wrote:
> > v4:
> > - Use copyright information without UTF-8 characters
> > v3:
> > - Fix wrong changes to spec/build/bsps/arm/xilinx-zynq/obj.yml
> > v2:
> > - Moved source file to bsps/shared/dev/spi
> > - Moved include files to bsps/include/dev/spi
> > - Enabled build in aarch64 BSPs
> > v1:
> > This patchset implements a driver for the cadence-spi device of the Xilinx
> Zynq-7000 based SoCs  using the spidev API.
> > Jan Sommer (3):
> >   bsps/xilinx_zynq: Add SPI driver for cadence-spi
> >   bsps/xilinx_zynq: Add SPI driver to waf
> >   bsps/xilinx_zynq: Add SPI driver to autotools build
> >  bsps/headers.am                               |   5 +
> >  bsps/include/dev/spi/cadence-spi-regs.h       |  84 ++++
> >  bsps/include/dev/spi/cadence-spi.h            |  48 ++
> >  bsps/shared/dev/spi/cadence-spi.c             | 437 ++++++++++++++++++
> >  c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am  |   3 +
> >  .../lib/libbsp/arm/xilinx-zynqmp/Makefile.am  |   3 +
> >  spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml |   2 +
> >  spec/build/bsps/arm/xilinx-zynq/grp.yml       |   2 +
> >  .../arm/xilinx-zynqmp/bspxilinxzynqmp.yml     |   2 +
> >  spec/build/bsps/objdevspizynq.yml             |  18 +
> >  10 files changed, 604 insertions(+)
> >  create mode 100644 bsps/include/dev/spi/cadence-spi-regs.h
> >  create mode 100644 bsps/include/dev/spi/cadence-spi.h
> >  create mode 100644 bsps/shared/dev/spi/cadence-spi.c  create mode
> > 100644 spec/build/bsps/objdevspizynq.yml
> > 2.17.1
> > devel mailing list
> > devel at rtems.org
