[PATCH rtems-net-legacy] netlegacy: Build libtelnetd.a and install header file in correct location
Gedare Bloom
gedare at rtems.org
Fri Mar 5 19:06:56 UTC 2021
On Fri, Mar 5, 2021 at 11:42 AM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> netlegacy.py | 27 +++++++++++++++++++++------
> testsuites/telnetd01/wscript | 2 +-
> 2 files changed, 22 insertions(+), 7 deletions(-)
> diff --git a/netlegacy.py b/netlegacy.py
> index 037e2ee..0889548 100644
> --- a/netlegacy.py
> +++ b/netlegacy.py
> @@ -31,7 +31,8 @@ import os
> source_files = []
> include_files = {}
> -exclude_dirs = ['pppd', 'nfsclient', 'testsuites', 'librpc/include', 'bsps']
> +exclude_dirs = ['pppd', 'nfsclient', 'testsuites', 'librpc/include', 'bsps',
> + 'telnetd']
> exclude_headers = ['rtems-bsd-user-space.h', 'rtems-bsd-kernel-space.h']
> for root, dirs, files in os.walk("."):
> @@ -51,6 +52,8 @@ def build(bld):
> bsp = bld.env.RTEMS_ARCH_BSP.split('-')[-1]
> pppd_source = [os.path.join('./pppd', s)
> for s in os.listdir('./pppd') if s[-2:] == '.c']
> + telnetd_source = [os.path.join('./telnetd', s)
> + for s in os.listdir('telnetd') if s[-2:] == '.c']
> bsp_dirs, bsp_sources = bsp_drivers.bsp_files(bld)
> @@ -98,12 +101,24 @@ def build(bld):
> use='networking',
> source=pppd_source)
> + bld.stlib(target='telnetd',
> + features='c',
> + includes=ip,
> + use='networking',
> + source=telnetd_source)
> bld.install_files(os.path.join('${PREFIX}', arch_lib_path),
> - ["libnetworking.a"])
> - bld.install_files(os.path.join('${PREFIX}', arch_lib_path),
> + ["libnetworking.a", 'libpppd.a', 'libtelnetd.a'])
> + bld.install_files(os.path.join('${PREFIX}', arch_lib_path,
> + 'include', 'libchip'),
> [os.path.join('./bsps/include/libchip/', f)
> for f in os.listdir('./bsps/include/libchip/')])
> for i in include_files:
> - arch_lib_path, i),
> - include_files[i])
> + if 'include' in i.split('/'):
> + arch_lib_path, i),
> + include_files[i])
> + else:
> + arch_lib_path, 'include', i),
> + include_files[i])
> diff --git a/testsuites/telnetd01/wscript b/testsuites/telnetd01/wscript
> index 8a48b90..fd573be 100644
> --- a/testsuites/telnetd01/wscript
> +++ b/testsuites/telnetd01/wscript
> @@ -42,5 +42,5 @@ def build(bld):
> features='c cprogram',
> cfags=['-O2', '-g'],
unrelated: should this be cflags?
go ahead and push the fix, you can be a little bit aggressive for a
few days to get this repo "stable"
> includes='. .. ../include ../../ ../../include',
> - use=['networking'],
> + use=['telnetd', 'networking'],
> source='init.c')
> 2.26.2
> devel mailing list
> devel at rtems.org
