[PATCH v2 2/4] main_chmod.c: Fix Unchecked return value from library (CID #1063856)
Ryan Long
thisisryanlong at gmail.com
Fri Mar 5 19:47:08 UTC 2021
CID 1063856: Unchecked return value from library in
rtems_shell_main_chmod().
Closes #4281
cpukit/libmisc/shell/main_chmod.c | 5 ++++-
1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/cpukit/libmisc/shell/main_chmod.c b/cpukit/libmisc/shell/main_chmod.c
index 0c39072..df18ef1 100644
--- a/cpukit/libmisc/shell/main_chmod.c
+++ b/cpukit/libmisc/shell/main_chmod.c
@@ -34,6 +34,7 @@ static int rtems_shell_main_chmod(
int n;
mode_t mode;
unsigned long tmp;
+ int sc;
if (argc < 2) {
fprintf(stderr,"%s: too few arguments\n", argv[0]);
@@ -53,7 +54,9 @@ static int rtems_shell_main_chmod(
* Now change the files modes
for (n=2 ; n < argc ; n++)
- chmod(argv[n++], mode);
+ sc = chmod(argv[n++], mode);
+ _Assert_Unused_variable_unequal(sc, -1);
return 0;
1.8.3.1
