[PATCH v2 0/4] Fix Unchecked return value from library issues
Fri Mar 5 19:59:58 UTC 2021
1, 3, 4 are fine. 2 needs to be fixed.
On Fri, Mar 5, 2021 at 12:47 PM Ryan Long <thisisryanlong at gmail.com> wrote:
> Hi,
> Here are the patches with the recommended fixes.
> Thanks,
> Ryan
> Ryan Long (4):
>   gen_uuid.c: Fix two Unchecked return value from library errors
>   main_chmod.c: Fix Unchecked return value from library (CID #1063856)
>   pwdgrp.c: Fix Unchecked return value from library (CID #1255518)
>   main_help.c: Unchecked return value from library (CID #1437650)
>  cpukit/libcsupport/src/pwdgrp.c   |  6 +++++-
>  cpukit/libmisc/shell/main_chmod.c |  5 ++++-
>  cpukit/libmisc/shell/main_help.c  |  3 ++-
>  cpukit/libmisc/uuid/gen_uuid.c    | 11 ++++++++---
>  4 files changed, 19 insertions(+), 6 deletions(-)
> 1.8.3.1
> devel mailing list
> devel at rtems.org
