[PATCH v3 1/4] gen_uuid.c: Fix two Unchecked return value from library errors
Ryan Long thisisryanlong at gmail.com
Fri Mar 5 20:42:28 UTC 2021
CID 1049146: Unchecked return value from library in get_clock().
CID 1049147: Unchecked return value from library in get_random_fd().
Closes #4280
 cpukit/libmisc/uuid/gen_uuid.c | 11 ++++++++---
 1 file changed, 8 insertions(+), 3 deletions(-)
diff --git a/cpukit/libmisc/uuid/gen_uuid.c b/cpukit/libmisc/uuid/gen_uuid.c
index 3ca75a0..5bb34c0 100644
--- a/cpukit/libmisc/uuid/gen_uuid.c
+++ b/cpukit/libmisc/uuid/gen_uuid.c
@@ -155,6 +155,7 @@ static int get_random_fd(void)
 	struct timeval	tv;
 	static int	fd = -2;
 	int		i;
+	int		sc;
 	if (fd == -2) {
 		gettimeofday(&tv, 0);
@@ -164,8 +165,10 @@ static int get_random_fd(void)
 			fd = open("/dev/random", O_RDONLY | O_NONBLOCK);
 		if (fd >= 0) {
 			i = fcntl(fd, F_GETFD);
-			if (i >= 0)
-				fcntl(fd, F_SETFD, i | FD_CLOEXEC);
+			if (i >= 0) {
+				sc = fcntl(fd, F_SETFD, i | FD_CLOEXEC);
+				_Assert_Unused_variable_unequal(sc, -1);
 #endif
 		srand((getpid() << ((sizeof(pid_t)*CHAR_BIT)>>1)) ^ getuid() ^ tv.tv_sec ^ tv.tv_usec);
@@ -334,6 +337,7 @@ static int get_clock(uint32_t *clock_high, uint32_t *clock_low,
 	uint64_t			clock_reg;
 	mode_t				save_umask;
 	int				len;
+	int				sc;
 	if (state_fd == -2) {
 		save_umask = umask(0);
@@ -426,7 +430,8 @@ try_again:
 		rewind(state_f);
 		fl.l_type = F_UNLCK;
-		fcntl(state_fd, F_SETLK, &fl);
+		sc = fcntl(state_fd, F_SETLK, &fl);
 	*clock_high = clock_reg >> 32;
1.8.3.1
