[PATCH] main_edit.c: Fix Unchecked return value (CID #1255318)
Fri Mar 5 23:26:53 UTC 2021
ok
On Fri, Mar 5, 2021 at 1:55 PM Ryan Long <thisisryanlong at gmail.com> wrote:
> CID 1255318: Unchecked return value in display_line().
> Updates #4257
>  cpukit/libmisc/shell/main_edit.c | 2 +-
>  1 file changed, 1 insertion(+), 1 deletion(-)
> diff --git a/cpukit/libmisc/shell/main_edit.c b/cpukit/libmisc/shell/main_edit.c
> index a011049..8ac7eee 100644
> --- a/cpukit/libmisc/shell/main_edit.c
> +++ b/cpukit/libmisc/shell/main_edit.c
> @@ -1089,7 +1089,7 @@ static void display_line(struct editor *ed, int pos, int fullline) {
>    int selstart, selend, ch;
>    char *s;
> -  get_selection(ed, &selstart, &selend);
> +  (void) get_selection(ed, &selstart, &selend);
>    while (col < maxcol) {
>      if (margin == 0) {
>        if (!hilite && pos >= selstart && pos < selend) {
> 1.8.3.1
> devel mailing list
> devel at rtems.org
