About HEAP error
Richi Dubey
richidubey at gmail.com
Sat Mar 6 04:58:40 UTC 2021
> This is just the detection point. The allocate is doing a validity check
> and something is wrong from an overwrite.
> FWIW this is pretty early in the test I think.
Good point, the corruption has already happened earlier, and yes its quite
early :
#13 0x0010860e in rtems_task_create (name=1413558560, initial_priority=1,
stack_size=4096, initial_modes=0, attribute_set=0, id=0x202444 <Task_id+4>)
at
/home/richi/quick-start/LatestStrong/src/rtems/c/src/../../cpukit/rtems/src/taskcreate.c:84
#14 0x001015fa in Init (argument=2107944) at
/home/richi/quick-start/LatestStrong/src/rtems/c/src/../../testsuites/sptests/sp02/init.c:101
Look manually at say 32 bytes at that address at various points during the
> program's execution. I think this is one where a binary search for the
> corrupting action happens.
Yes, or maybe I would try to manually put a watchpoint at all the 32 bytes
starting 0x202ba8 and see if it works.
Is this using your scheduler as the default? If so, I'd be suspicious of
> anything allocated for it and if you were riding outside an area allocated
> for you.
Yes! Maybe the scheduler access a variable outside its bound (maybe an
array element outside its array size), but if that is true, there should be
a lot more failure with HEAP_ERROR. I would still give it a look.
Thanks again for your help.
On Fri, Mar 5, 2021 at 7:01 PM Joel Sherrill <joel at rtems.org> wrote:
> On Thu, Mar 4, 2021, 11:31 PM Richi Dubey <richidubey at gmail.com> wrote:
>> Hi,
>> Thanks to both of you for helping me out with this!
>> When I backtrace on _Terminate: I get this:
>> Init -> rtems_task_create -> ... -> _Heap_Allocate -> ...
>> ->_Heap_Protection_check_free_block -> _Heap_Protection_block_error
>> ->_Heap_Protection_block_error_default -> _Terminate
>> (the_source=RTEMS_FATAL_SOURCE_HEAP, the_error=2125180). So I will try to
>> debug this trace.
>> Also, setting a watchpoint doesn't help:
> for you.
>> Thread 1 hit Breakpoint 6, Init (argument=2107944) at
>> /home/richi/quick-start/LatestStrong/src/rtems/c/src/../../testsuites/sptests/sp02/init.c:26
>> 26 TEST_BEGIN();
>> (gdb) watch *(unsigned int)* 0x202ba8
>> Hardware watchpoint 13: *(unsigned int)* 0x202ba8
>> (gdb) c
>> Continuing.
>> Thread 1 hit Breakpoint 5, _Terminate
>> (the_source=RTEMS_FATAL_SOURCE_HEAP, the_error=2125180) at
>> /home/richi/quick-start/LatestStrong/src/rtems/c/src/../../cpukit/score/src/interr.c:38
>> 38 _User_extensions_Fatal( the_source, the_error );
>> On Wed, Mar 3, 2021 at 10:20 PM Gedare Bloom <gedare at rtems.org> wrote:
>>> On Wed, Mar 3, 2021 at 9:49 AM Gedare Bloom <gedare at rtems.org> wrote:
>>> > On Wed, Mar 3, 2021 at 9:28 AM Joel Sherrill <joel.sherrill at gmail.com>
>>> wrote:
>>> > > On Wed, Mar 3, 2021 at 9:50 AM Gedare Bloom <gedare at rtems.org>
>>> wrote:
>>> > >> On Wed, Mar 3, 2021 at 12:08 AM Richi Dubey <richidubey at gmail.com>
>>> wrote:
>>> > >> > What's the element written after the free? I set a watch at the
>>> exact block location, but it doesn't work:
>>> > >> > Hardware watchpoint 7: *0x202ba8
>>> > >> > (gdb) watch *0x206fec
>>> > >> > Hardware watchpoint 8: *0x206fec
>>> > >> That's just the first byte in the block. If you can figure out which
>>> > >> bytes/words in the block get accessed that would help you.
>>> > > What about watch *(unsigned int)* 0x202ba8?
>>> > > Won't that look at more bytes?
>>> > And this is just the first byte of the workspace area.
>>> 4 bytes :)
>>> > > In case you do need to look at more bytes in the fence...
>>> > > breaking at _Terminate and doing a back trace will give
>>> > > you the exact line the error is raised from. You can then set a
>>> > > breakpoint at that on the next line and look at local variables.
>>> > > The corruption may be in the fence somewhere beyond the
>>> > > first 32-bits.
>>> In the case of heap corruption, the corruption is detected after it
>>> already happened. Narrowing down when/where the corruption happens is
>>> necessary. The next thing to do would be to examine the pattern that
>>> triggers the violation, and see where it got modified. This might
>>> provide a byte address to set a watch on.
>>> > > Sometimes it is easy to binary search for an issue like this
>>> > > on a simulator. But with a watchpoint, you should be able to
>>> > > determine the precise word which is corrupted in the fence
>>> > > and break on that write.
>>> > > --joel
>>> > >> > (gdb) c
>>> > >> > Continuing.
>>> > >> > 26 TEST_BEGIN();
>>> > >> > (gdb)
>>> > >> > Continuing.
>>> > >> > (gdb)
>>> > >> > Continuing.
>>> > >> > Thread 1 hit Breakpoint 4, bsp_reset () at
>>> /home/richi/quick-start/LatestStrong/src/rtems/c/src/lib/libbsp/arm/realview-pbx-a9/../../../../../../bsps/arm/realview-pbx-a9/start/bspreset.c:19
>>> > >> > 19 volatile uint32_t *sys_lock = (volatile uint32_t *)
>>> 0x10000020;
>>> > >> > (gdb)
>>> > >> > On Wed, Mar 3, 2021 at 12:31 PM Sebastian Huber <
>>> sebastian.huber at embedded-brains.de> wrote:
>>> > >> >> On 02/03/2021 05:44, Richi Dubey wrote:
>>> > >> >> > (gdb) p *(Heap_Error_context*)(0x00206d7c)
>>> > >> >> > $5 = {
>>> > >> >> > heap = 0x202ba8 <_Workspace_Area>,
>>> > >> >> > block = 0x206fec,
>>> > >> >> > reason = HEAP_ERROR_FREE_PATTERN
>>> > >> >> If it is always the same address, then you can set a watch point
>>> to an
>>> > >> >> element which is written after the free to catch the function
>>> which
>>> > >> >> writes into this area.
>>> > >> >> embedded brains GmbH
>>> > >> >> Herr Sebastian HUBER
>>> > >> >> Dornierstr. 4
>>> > >> >> 82178 Puchheim
>>> > >> >> Germany
>>> > >> >> email: sebastian.huber at embedded-brains.de
>>> > >> >> phone: +49-89-18 94 741 - 16
>>> > >> >> fax: +49-89-18 94 741 - 08
>>> > >> >> Registergericht: Amtsgericht München
>>> > >> >> Registernummer: HRB 157899
>>> > >> >> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas
>>> Dörfler
>>> > >> >> Unsere Datenschutzerklärung finden Sie hier:
>>> > >> >> https://embedded-brains.de/datenschutzerklaerung/
>>> > >> > _______________________________________________
>>> > >> > devel mailing list
>>> > >> > devel at rtems.org
>>> > >> > http://lists.rtems.org/mailman/listinfo/devel
>>> > >> devel mailing list
>>> > >> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210306/a94bb36d/attachment-0001.html>
