[PATCH 0/3] Fix Missing break in switch Coverity issues
Tue Mar 9 06:04:25 UTC 2021
On 09/03/2021 06:47, Gedare Bloom wrote:
>>>> I would just use a comment which is understood by GCC, clang, and
>>>> Coverity. What does Linux use?
>>> That's fine, if there is a de facto standard to use, we can go for it.
>> Looking at the option documentation gcc supports a lot of different possible
>> ways and the warning option can change what is selected.
>> Do we allow all that gcc allows? I hope not.
> As with other things we should provide a portable way to maintain it.
> I would suggest adding to basedefs.h:
> #define RTEMS_CASE_FALL_THROUGH
> macro as reasonably simple. We can debate a few variations
> RTEMS_CASE_FALLTHRU is short and sufficient.
> Most likely we'll never have to change it, but this will simplify code
> review and avoid typos /* fall-trough */
Linux uses a macro:
https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/commit/?id=2bf74771ca5610b10c3ac4cd17aacc389e6927ca
My favorite name is RTEMS_FALL_THROUGH.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
