[PATCH, RSB] sparc, leon: GCC-7.5 patch needed for LEON3FT TN0018 errata
Daniel Hellstrom
daniel at gaisler.com
Tue Mar 9 14:19:33 UTC 2021
Set the __FIX_LEON3FT_TN0018 define for the affected LEON3FT multilibs:
* UT699
* UT700
* GR712RC
Update #4322.
rtems/config/5/rtems-sparc.bset | 6 ++++++
1 file changed, 6 insertions(+)
diff --git a/rtems/config/5/rtems-sparc.bset b/rtems/config/5/rtems-sparc.bset
index ccb3e10..3d4d403 100644
--- a/rtems/config/5/rtems-sparc.bset
+++ b/rtems/config/5/rtems-sparc.bset
@@ -4,3 +4,9 @@
%define gdb-disable-sim 1
%include 5/rtems-default.bset
devel/sis-2-1
+# Add GCC patch to set __FIX_LEON3FT_TN0018 for the affected multilibs
+%patch add gcc -p1 https://devel.rtems.org/raw-attachment/ticket/4322/gcc-7.5-sparc-rtems-add-__FIX_LEON3FT_TN0018-for-affected-ta.patch
+%hash sha512 gcc-7.5-sparc-rtems-add-__FIX_LEON3FT_TN0018-for-affected-ta.patch bd215d6e09e7673a7766c1bdcbe15705f880ca1d1e1dc3be70d1fedeea68e0654334a57fef11d07c2e4a56153353628858b62ce199107802a913ca85e257b127
2.7.4
