[PATCH] sb/config.py: Fix operator reconstruction
Thu Mar 11 15:26:51 UTC 2021
Looks alright, Vijay can you push?
On Thu, Mar 11, 2021 at 12:32 AM Ricardo Cárdenes <rcardenes at gemini.edu> wrote:
> Close #4335
>  source-builder/sb/config.py | 6 +++---
>  1 file changed, 3 insertions(+), 3 deletions(-)
> diff --git a/source-builder/sb/config.py b/source-builder/sb/config.py
> index d3ba6cd..5bc96e2 100644
> --- a/source-builder/sb/config.py
> +++ b/source-builder/sb/config.py
> @@ -991,9 +991,9 @@ class file:
>              else:
>                  if len(ifls) >= 3:
>                      for op in ['==', '!=', '>=', '=>', '=<', '<=', '>', '<']:
> -                        ops = s.split(op)
> -                        if len(ops) == 2:
> -                            ifls = (ops[0], op, ops[1])
> +                        if op in ifls:
> +                            op_pos = ifls.index(op)
> +                            ifls = (' '.join(ifls[:op_pos]), op, ' '.join(ifls[op_pos + 1:]))
>                              break
>                  if len(ifls) != 3:
>                       self._error('malformed if: ' + reduce(add, ls, ''))
> 2.27.0
> devel mailing list
> devel at rtems.org
