[PATCH] shell.c: Dereference after null check (CID #26083)
Thu Mar 11 16:16:41 UTC 2021
On Thu, Mar 11, 2021 at 8:56 AM Ryan Long <ryan.long at oarcorp.com> wrote:
> After talking with Joel, we determined that 'out' shouldn’t be NULL by the time it gets to rtems_shell_login().
> We think that we should put in an assert to check whether stdin and stdout is NULL at https://git.rtems.org/rtems/tree/cpukit/libmisc/shell/shell.c#n968.
> Instead of the check that I put in for this patch, we think it's better to just put another assert at https://git.rtems.org/rtems/tree/cpukit/libmisc/shell/shell.c#n791 for 'out' out of paranoia and to get rid of the Coverity issue.
works for me.
> -----Original Message-----
> From: Gedare Bloom <gedare at rtems.org>
> Sent: Wednesday, March 10, 2021 4:50 PM
> To: Ryan Long <ryan.long at oarcorp.com>
> Cc: devel at rtems.org
> Subject: Re: [PATCH] shell.c: Dereference after null check (CID #26083)
> I need an explanation, I don't know if it is correct, or if someone can open a shell without an 'out' FILE?
> On Wed, Mar 10, 2021 at 12:10 PM Ryan Long <ryan.long at oarcorp.com> wrote:
> > CID 26083: Dereference after null check in rtems_shell_login().
> > Closes #4327
> >  cpukit/libmisc/shell/shell.c | 196
> >  1 file changed, 99 insertions(+), 97 deletions(-)
> > diff --git a/cpukit/libmisc/shell/shell.c
> > b/cpukit/libmisc/shell/shell.c index 1e5962b..b724b1d 100644
> > --- a/cpukit/libmisc/shell/shell.c
> > +++ b/cpukit/libmisc/shell/shell.c
> > @@ -683,109 +683,111 @@ static bool rtems_shell_login(rtems_shell_env_t *env, FILE * in,FILE * out)
> >    int    c;
> >    time_t t;
> > -  if (out) {
> > -    if ((env->devname[5]!='p')||
> > -        (env->devname[6]!='t')||
> > -        (env->devname[7]!='y')) {
> > -      fd = fopen("/etc/issue","r");
> > -      if (fd) {
> > -        while ((c = fgetc(fd)) != EOF) {
> > -          if (c=='@')  {
> > -            switch (c = fgetc(fd)) {
> > -              case 'L':
> > -                fprintf(out,"%s", env->devname);
> > -                break;
> > -              case 'B':
> > -                fprintf(out,"0");
> > -                break;
> > -              case 'T':
> > -              case 'D':
> > -                time(&t);
> > -                fprintf(out,"%s",ctime(&t));
> > -                break;
> > -              case 'S':
> > -                fprintf(out,"RTEMS");
> > -                break;
> > -              case 'V':
> > -                fprintf(
> > -                  out,
> > -                  "%s\n%s",
> > -                  rtems_get_version_string(),
> > -                  rtems_get_copyright_notice()
> > -                break;
> > -              case '@':
> > -                fprintf(out,"@");
> > -                break;
> > -              default :
> > -                fprintf(out,"@%c",c);
> > -                break;
> > -          } else if (c=='\\')  {
> > -            switch(c=fgetc(fd)) {
> > -              case '\\': fprintf(out,"\\"); break;
> > -              case 'b':  fprintf(out,"\b"); break;
> > -              case 'f':  fprintf(out,"\f"); break;
> > -              case 'n':  fprintf(out,"\n"); break;
> > -              case 'r':  fprintf(out,"\r"); break;
> > -              case 's':  fprintf(out," ");  break;
> > -              case 't':  fprintf(out,"\t"); break;
> > -              case '@':  fprintf(out,"@");  break;
> > -          } else {
> > -            fputc(c,out);
> > +  if (out == NULL) {
> > +    return false;
> > +  if ((env->devname[5]!='p')||
> > +      (env->devname[6]!='t')||
> > +      (env->devname[7]!='y')) {
> > +    fd = fopen("/etc/issue","r");
> > +    if (fd) {
> > +      while ((c = fgetc(fd)) != EOF) {
> > +        if (c=='@')  {
> > +          switch (c = fgetc(fd)) {
> > +            case 'L':
> > +              fprintf(out,"%s", env->devname);
> > +              break;
> > +            case 'B':
> > +              fprintf(out,"0");
> > +              break;
> > +            case 'T':
> > +            case 'D':
> > +              time(&t);
> > +              fprintf(out,"%s",ctime(&t));
> > +              break;
> > +            case 'S':
> > +              fprintf(out,"RTEMS");
> > +              break;
> > +            case 'V':
> > +              fprintf(
> > +                out,
> > +                "%s\n%s",
> > +                rtems_get_version_string(),
> > +                rtems_get_copyright_notice()
> > +              break;
> > +            case '@':
> > +              fprintf(out,"@");
> > +              break;
> > +            default :
> > +              fprintf(out,"@%c",c);
> > +              break;
> > +        } else if (c=='\\')  {
> > +          switch(c=fgetc(fd)) {
> > +            case '\\': fprintf(out,"\\"); break;
> > +            case 'b':  fprintf(out,"\b"); break;
> > +            case 'f':  fprintf(out,"\f"); break;
> > +            case 'n':  fprintf(out,"\n"); break;
> > +            case 'r':  fprintf(out,"\r"); break;
> > +            case 's':  fprintf(out," ");  break;
> > +            case 't':  fprintf(out,"\t"); break;
> > +            case '@':  fprintf(out,"@");  break;
> > +        } else {
> > +          fputc(c,out);
> > -        fclose(fd);
> > -    } else {
> > -      fd = fopen("/etc/issue.net","r");
> > -      if (fd) {
> > -        while ((c=fgetc(fd))!=EOF) {
> > -          if (c=='%')  {
> > -              case 't':
> > -                break;
> > -              case 'h':
> > -                fprintf(out,"0");
> > -                break;
> > -              case 'D':
> > -                fprintf(out," ");
> > -                break;
> > -              case 'd':
> > -                time(&t);
> > -                break;
> > -              case 's':
> > -                break;
> > -              case 'm':
> > -                fprintf(out,"(" CPU_NAME "/" CPU_MODEL_NAME ")");
> > -                break;
> > -              case 'r':
> > -                fprintf(out,rtems_get_version_string());
> > -                break;
> > -              case 'v':
> > -                fprintf(
> > -                  out,
> > -                  "%s\n%s",
> > -               break;
> > -             case '%':fprintf(out,"%%");
> > -               break;
> > -             default:
> > -                fprintf(out,"%%%c",c);
> > -                break;
> > -          } else {
> > -            fputc(c,out);
> > +      fclose(fd);
> > +  } else {
> > +    fd = fopen("/etc/issue.net","r");
> > +    if (fd) {
> > +      while ((c=fgetc(fd))!=EOF) {
> > +        if (c=='%')  {
> > +            case 't':
> > +              break;
> > +            case 'h':
> > +              fprintf(out,"0");
> > +              break;
> > +            case 'D':
> > +              fprintf(out," ");
> > +              break;
> > +            case 'd':
> > +              time(&t);
> > +              break;
> > +            case 's':
> > +              break;
> > +            case 'm':
> > +              fprintf(out,"(" CPU_NAME "/" CPU_MODEL_NAME ")");
> > +              break;
> > +            case 'r':
> > +              fprintf(out,rtems_get_version_string());
> > +              break;
> > +            case 'v':
> > +              fprintf(
> > +                out,
> > +                "%s\n%s",
> > +              break;
> > +            case '%':fprintf(out,"%%");
> > +              break;
> > +            default:
> > +              fprintf(out,"%%%c",c);
> > +              break;
> > +        } else {
> > +          fputc(c,out);
> > -        fclose(fd);
> > +      fclose(fd);
> > 1.8.3.1
> > devel mailing list
> > devel at rtems.org
