[PATCH] covoar/TargetBase: Rename branchInstructions to conditionalBranchInstructions
Thu Mar 11 16:33:47 UTC 2021
looks ok
On Thu, Mar 11, 2021 at 9:25 AM Alex White <alex.white at oarcorp.com> wrote:
> The TargetBase class contains a member variable named
> branchInstructions. The name omits the fact that it is only meant to
> contain conditional branch instructions. Its name has been changed to
> conditionalBranchInstructions to avoid confusion.
>  tester/covoar/TargetBase.cc     | 10 +++-
>  tester/covoar/TargetBase.h      |  4 +-
>  tester/covoar/Target_arm.cc     | 34 ++++++------
>  tester/covoar/Target_i386.cc    | 64 ++++++++++-----------
>  tester/covoar/Target_lm32.cc    | 12 ++--
>  tester/covoar/Target_m68k.cc    | 98 ++++++++++++++++-----------------
>  tester/covoar/Target_powerpc.cc | 56 +++++++++----------
>  tester/covoar/Target_riscv.cc   | 22 ++++----
>  tester/covoar/Target_sparc.cc   | 66 +++++++++++-----------
>  9 files changed, 185 insertions(+), 181 deletions(-)
> diff --git a/tester/covoar/TargetBase.cc b/tester/covoar/TargetBase.cc
> index 354a580..4474fad 100644
> --- a/tester/covoar/TargetBase.cc
> +++ b/tester/covoar/TargetBase.cc
> @@ -66,15 +66,19 @@ namespace Target {
>      std::list <std::string>::iterator i;
> -    if (branchInstructions.empty()) {
> +    if (conditionalBranchInstructions.empty()) {
>        throw rld::error(
>          "DETERMINE BRANCH INSTRUCTIONS FOR THIS ARCHITECTURE! -- fix me",
>          "TargetBase::isBranch"
> -    i = find(branchInstructions.begin(), branchInstructions.end(), instruction);
> -    if ( i  == branchInstructions.end() )
> +    i = find(
> +      conditionalBranchInstructions.begin(),
> +      conditionalBranchInstructions.end(),
> +      instruction
> +    if ( i  == conditionalBranchInstructions.end() )
>        return false;
>      return true;
> diff --git a/tester/covoar/TargetBase.h b/tester/covoar/TargetBase.h
> index 14cd6f2..e566c15 100644
> --- a/tester/covoar/TargetBase.h
> +++ b/tester/covoar/TargetBase.h
> @@ -135,10 +135,10 @@ namespace Target {
>      bool objdumpHasTabs;
> -     * This member variable is an array of all branch instructions
> +     * This member variable is an array of all conditional branch instructions
>       * for this target.
> -    std::list <std::string> branchInstructions;
> +    std::list <std::string> conditionalBranchInstructions;
>    private:
> diff --git a/tester/covoar/Target_arm.cc b/tester/covoar/Target_arm.cc
> index a33ec80..4b7b2e1 100644
> --- a/tester/covoar/Target_arm.cc
> +++ b/tester/covoar/Target_arm.cc
> @@ -19,24 +19,24 @@ namespace Target {
>    Target_arm::Target_arm( std::string targetName ):
>      TargetBase( targetName )
> -    branchInstructions.push_back("bcc");
> -    branchInstructions.push_back("bcs");
> -    branchInstructions.push_back("beq");
> -    branchInstructions.push_back("bge");
> -    branchInstructions.push_back("bgt");
> -    branchInstructions.push_back("bhi");
> -    branchInstructions.push_back("bl-hi");
> -    branchInstructions.push_back("bl-lo");
> -    branchInstructions.push_back("ble");
> -    branchInstructions.push_back("bls");
> -    branchInstructions.push_back("blt");
> -    branchInstructions.push_back("bmi");
> -    branchInstructions.push_back("bne");
> -    branchInstructions.push_back("bpl");
> -    branchInstructions.push_back("bvc");
> -    branchInstructions.push_back("bvs");
> +    conditionalBranchInstructions.push_back("bcc");
> +    conditionalBranchInstructions.push_back("bcs");
> +    conditionalBranchInstructions.push_back("beq");
> +    conditionalBranchInstructions.push_back("bge");
> +    conditionalBranchInstructions.push_back("bgt");
> +    conditionalBranchInstructions.push_back("bhi");
> +    conditionalBranchInstructions.push_back("bl-hi");
> +    conditionalBranchInstructions.push_back("bl-lo");
> +    conditionalBranchInstructions.push_back("ble");
> +    conditionalBranchInstructions.push_back("bls");
> +    conditionalBranchInstructions.push_back("blt");
> +    conditionalBranchInstructions.push_back("bmi");
> +    conditionalBranchInstructions.push_back("bne");
> +    conditionalBranchInstructions.push_back("bpl");
> +    conditionalBranchInstructions.push_back("bvc");
> +    conditionalBranchInstructions.push_back("bvs");
> -    branchInstructions.sort();
> +    conditionalBranchInstructions.sort();
> diff --git a/tester/covoar/Target_i386.cc b/tester/covoar/Target_i386.cc
> index 0f82f18..e0c9c0f 100644
> --- a/tester/covoar/Target_i386.cc
> +++ b/tester/covoar/Target_i386.cc
> @@ -16,39 +16,39 @@ namespace Target {
>    Target_i386::Target_i386( std::string targetName ):
> -    branchInstructions.push_back("ja");
> -    branchInstructions.push_back("jb");
> -    branchInstructions.push_back("jc");
> -    branchInstructions.push_back("je");
> -    branchInstructions.push_back("jg");
> -    branchInstructions.push_back("jl");
> -    branchInstructions.push_back("jo");
> -    branchInstructions.push_back("jp");
> -    branchInstructions.push_back("js");
> -    branchInstructions.push_back("jz");
> -    branchInstructions.push_back("jae");
> -    branchInstructions.push_back("jbe");
> -    branchInstructions.push_back("jge");
> -    branchInstructions.push_back("jle");
> -    branchInstructions.push_back("jne");
> -    branchInstructions.push_back("jna");
> -    branchInstructions.push_back("jnb");
> -    branchInstructions.push_back("jnc");
> -    branchInstructions.push_back("jng");
> -    branchInstructions.push_back("jnl");
> -    branchInstructions.push_back("jno");
> -    branchInstructions.push_back("jnp");
> -    branchInstructions.push_back("jns");
> -    branchInstructions.push_back("jnz");
> -    branchInstructions.push_back("jpe");
> -    branchInstructions.push_back("jpo");
> -    branchInstructions.push_back("jnbe");
> -    branchInstructions.push_back("jnae");
> -    branchInstructions.push_back("jnle");
> -    branchInstructions.push_back("jnge");
> +    conditionalBranchInstructions.push_back("ja");
> +    conditionalBranchInstructions.push_back("jb");
> +    conditionalBranchInstructions.push_back("jc");
> +    conditionalBranchInstructions.push_back("je");
> +    conditionalBranchInstructions.push_back("jg");
> +    conditionalBranchInstructions.push_back("jl");
> +    conditionalBranchInstructions.push_back("jo");
> +    conditionalBranchInstructions.push_back("jp");
> +    conditionalBranchInstructions.push_back("js");
> +    conditionalBranchInstructions.push_back("jz");
> +    conditionalBranchInstructions.push_back("jae");
> +    conditionalBranchInstructions.push_back("jbe");
> +    conditionalBranchInstructions.push_back("jge");
> +    conditionalBranchInstructions.push_back("jle");
> +    conditionalBranchInstructions.push_back("jne");
> +    conditionalBranchInstructions.push_back("jna");
> +    conditionalBranchInstructions.push_back("jnb");
> +    conditionalBranchInstructions.push_back("jnc");
> +    conditionalBranchInstructions.push_back("jng");
> +    conditionalBranchInstructions.push_back("jnl");
> +    conditionalBranchInstructions.push_back("jno");
> +    conditionalBranchInstructions.push_back("jnp");
> +    conditionalBranchInstructions.push_back("jns");
> +    conditionalBranchInstructions.push_back("jnz");
> +    conditionalBranchInstructions.push_back("jpe");
> +    conditionalBranchInstructions.push_back("jpo");
> +    conditionalBranchInstructions.push_back("jnbe");
> +    conditionalBranchInstructions.push_back("jnae");
> +    conditionalBranchInstructions.push_back("jnle");
> +    conditionalBranchInstructions.push_back("jnge");
> diff --git a/tester/covoar/Target_lm32.cc b/tester/covoar/Target_lm32.cc
> index 988c735..93184ec 100644
> --- a/tester/covoar/Target_lm32.cc
> +++ b/tester/covoar/Target_lm32.cc
> @@ -17,12 +17,12 @@ namespace Target {
>    Target_lm32::Target_lm32( std::string targetName ):
> -    branchInstructions.push_back("be");
> -    branchInstructions.push_back("bgeu");
> -    branchInstructions.push_back("bg");
> -    branchInstructions.push_back("bgu");
> +    conditionalBranchInstructions.push_back("be");
> +    conditionalBranchInstructions.push_back("bgeu");
> +    conditionalBranchInstructions.push_back("bg");
> +    conditionalBranchInstructions.push_back("bgu");
>    Target_lm32::~Target_lm32()
> diff --git a/tester/covoar/Target_m68k.cc b/tester/covoar/Target_m68k.cc
> index 5dc7993..536ae80 100644
> --- a/tester/covoar/Target_m68k.cc
> +++ b/tester/covoar/Target_m68k.cc
> @@ -19,56 +19,56 @@ namespace Target {
>    Target_m68k::Target_m68k( std::string targetName ):
> -    branchInstructions.push_back("bccs");
> -    branchInstructions.push_back("bccl");
> -    branchInstructions.push_back("bcss");
> -    branchInstructions.push_back("bcsl");
> -    branchInstructions.push_back("beqs");
> -    branchInstructions.push_back("beql");
> -    branchInstructions.push_back("bges");
> -    branchInstructions.push_back("bgel");
> -    branchInstructions.push_back("bgts");
> -    branchInstructions.push_back("bgtl");
> -    branchInstructions.push_back("bhis");
> -    branchInstructions.push_back("bhil");
> -    branchInstructions.push_back("bhs");
> -    branchInstructions.push_back("bhss");
> -    branchInstructions.push_back("bhsl");
> -    branchInstructions.push_back("bles");
> -    branchInstructions.push_back("blel");
> -    branchInstructions.push_back("blo");
> -    branchInstructions.push_back("blos");
> -    branchInstructions.push_back("blol");
> -    branchInstructions.push_back("blss");
> -    branchInstructions.push_back("blsl");
> -    branchInstructions.push_back("blts");
> -    branchInstructions.push_back("bltl");
> -    branchInstructions.push_back("bmis");
> -    branchInstructions.push_back("bmil");
> -    branchInstructions.push_back("bnes");
> -    branchInstructions.push_back("bnel");
> -    branchInstructions.push_back("bpls");
> -    branchInstructions.push_back("bpll");
> -    branchInstructions.push_back("bvcs");
> -    branchInstructions.push_back("bvcl");
> -    branchInstructions.push_back("bvss");
> -    branchInstructions.push_back("bvsl");
> +    conditionalBranchInstructions.push_back("bccs");
> +    conditionalBranchInstructions.push_back("bccl");
> +    conditionalBranchInstructions.push_back("bcss");
> +    conditionalBranchInstructions.push_back("bcsl");
> +    conditionalBranchInstructions.push_back("beqs");
> +    conditionalBranchInstructions.push_back("beql");
> +    conditionalBranchInstructions.push_back("bges");
> +    conditionalBranchInstructions.push_back("bgel");
> +    conditionalBranchInstructions.push_back("bgts");
> +    conditionalBranchInstructions.push_back("bgtl");
> +    conditionalBranchInstructions.push_back("bhis");
> +    conditionalBranchInstructions.push_back("bhil");
> +    conditionalBranchInstructions.push_back("bhs");
> +    conditionalBranchInstructions.push_back("bhss");
> +    conditionalBranchInstructions.push_back("bhsl");
> +    conditionalBranchInstructions.push_back("bles");
> +    conditionalBranchInstructions.push_back("blel");
> +    conditionalBranchInstructions.push_back("blo");
> +    conditionalBranchInstructions.push_back("blos");
> +    conditionalBranchInstructions.push_back("blol");
> +    conditionalBranchInstructions.push_back("blss");
> +    conditionalBranchInstructions.push_back("blsl");
> +    conditionalBranchInstructions.push_back("blts");
> +    conditionalBranchInstructions.push_back("bltl");
> +    conditionalBranchInstructions.push_back("bmis");
> +    conditionalBranchInstructions.push_back("bmil");
> +    conditionalBranchInstructions.push_back("bnes");
> +    conditionalBranchInstructions.push_back("bnel");
> +    conditionalBranchInstructions.push_back("bpls");
> +    conditionalBranchInstructions.push_back("bpll");
> +    conditionalBranchInstructions.push_back("bvcs");
> +    conditionalBranchInstructions.push_back("bvcl");
> +    conditionalBranchInstructions.push_back("bvss");
> +    conditionalBranchInstructions.push_back("bvsl");
> diff --git a/tester/covoar/Target_powerpc.cc b/tester/covoar/Target_powerpc.cc
> index 3444b3c..c62feb0 100644
> --- a/tester/covoar/Target_powerpc.cc
> +++ b/tester/covoar/Target_powerpc.cc
> @@ -21,36 +21,36 @@ namespace Target {
>      // bl is actually branch and link which is a call
>      // branchInstructions.push_back("b");
>      // branchInstructions.push_back("ba");
> -    branchInstructions.push_back("beq+");
> -    branchInstructions.push_back("beq-");
> -    branchInstructions.push_back("bne+");
> -    branchInstructions.push_back("bne-");
> -    branchInstructions.push_back("bge+");
> -    branchInstructions.push_back("bge-");
> -    branchInstructions.push_back("bgt+");
> -    branchInstructions.push_back("bgt-");
> -    branchInstructions.push_back("ble+");
> -    branchInstructions.push_back("ble-");
> -    branchInstructions.push_back("blt+");
> -    branchInstructions.push_back("blt-");
> -    branchInstructions.push_back("bla");
> -    branchInstructions.push_back("bc");
> -    branchInstructions.push_back("bca");
> -    branchInstructions.push_back("bcl");
> -    branchInstructions.push_back("bcla");
> -    branchInstructions.push_back("bcctr");
> -    branchInstructions.push_back("bcctrl");
> -    branchInstructions.push_back("bclr");
> -    branchInstructions.push_back("bclrl");
> +    conditionalBranchInstructions.push_back("beq+");
> +    conditionalBranchInstructions.push_back("beq-");
> +    conditionalBranchInstructions.push_back("bne+");
> +    conditionalBranchInstructions.push_back("bne-");
> +    conditionalBranchInstructions.push_back("bge+");
> +    conditionalBranchInstructions.push_back("bge-");
> +    conditionalBranchInstructions.push_back("bgt+");
> +    conditionalBranchInstructions.push_back("bgt-");
> +    conditionalBranchInstructions.push_back("ble+");
> +    conditionalBranchInstructions.push_back("ble-");
> +    conditionalBranchInstructions.push_back("blt+");
> +    conditionalBranchInstructions.push_back("blt-");
> +    conditionalBranchInstructions.push_back("bla");
> +    conditionalBranchInstructions.push_back("bc");
> +    conditionalBranchInstructions.push_back("bca");
> +    conditionalBranchInstructions.push_back("bcl");
> +    conditionalBranchInstructions.push_back("bcla");
> +    conditionalBranchInstructions.push_back("bcctr");
> +    conditionalBranchInstructions.push_back("bcctrl");
> +    conditionalBranchInstructions.push_back("bclr");
> +    conditionalBranchInstructions.push_back("bclrl");
>    Target_powerpc::~Target_powerpc()
> diff --git a/tester/covoar/Target_riscv.cc b/tester/covoar/Target_riscv.cc
> index 279dc6a..13c81c5 100644
> --- a/tester/covoar/Target_riscv.cc
> +++ b/tester/covoar/Target_riscv.cc
> @@ -43,18 +43,18 @@ namespace Target {
>    Target_riscv::Target_riscv( std::string targetName ):
> -    branchInstructions.push_back("beqz");
> -    branchInstructions.push_back("bnez");
> -    branchInstructions.push_back("blez");
> -    branchInstructions.push_back("bgez");
> -    branchInstructions.push_back("bltz");
> -    branchInstructions.push_back("bgtz");
> -    branchInstructions.push_back("bgtu");
> -    branchInstructions.push_back("bleu");
> +    conditionalBranchInstructions.push_back("beqz");
> +    conditionalBranchInstructions.push_back("bnez");
> +    conditionalBranchInstructions.push_back("blez");
> +    conditionalBranchInstructions.push_back("bgez");
> +    conditionalBranchInstructions.push_back("bltz");
> +    conditionalBranchInstructions.push_back("bgtz");
> +    conditionalBranchInstructions.push_back("bgtu");
> +    conditionalBranchInstructions.push_back("bleu");
>    Target_riscv::~Target_riscv()
> diff --git a/tester/covoar/Target_sparc.cc b/tester/covoar/Target_sparc.cc
> index 0e4ab2e..eab2684 100644
> --- a/tester/covoar/Target_sparc.cc
> +++ b/tester/covoar/Target_sparc.cc
> @@ -15,40 +15,40 @@ namespace Target {
>    Target_sparc::Target_sparc( std::string targetName ):
> -    branchInstructions.push_back("bn");
> -    branchInstructions.push_back("bn,a");
> -    branchInstructions.push_back("be,a");
> -    branchInstructions.push_back("ble,a");
> -    branchInstructions.push_back("bl");
> -    branchInstructions.push_back("bl,a");
> -    branchInstructions.push_back("bleu,a");
> -    branchInstructions.push_back("bcs,a");
> -    branchInstructions.push_back("bneg");
> -    branchInstructions.push_back("bneg,a");
> -    branchInstructions.push_back("bvs,a");
> -    branchInstructions.push_back("ba");
> -    branchInstructions.push_back("ba,a");
> -    branchInstructions.push_back("bne,a");
> -    branchInstructions.push_back("bg,a");
> -    branchInstructions.push_back("bge,a");
> -    branchInstructions.push_back("bgu,a");
> -    branchInstructions.push_back("bcc,a");
> -    branchInstructions.push_back("bpos");
> -    branchInstructions.push_back("bpos,a");
> -    branchInstructions.push_back("bvc,a");
> +    conditionalBranchInstructions.push_back("bn");
> +    conditionalBranchInstructions.push_back("bn,a");
> +    conditionalBranchInstructions.push_back("be,a");
> +    conditionalBranchInstructions.push_back("ble,a");
> +    conditionalBranchInstructions.push_back("bl");
> +    conditionalBranchInstructions.push_back("bl,a");
> +    conditionalBranchInstructions.push_back("bleu,a");
> +    conditionalBranchInstructions.push_back("bcs,a");
> +    conditionalBranchInstructions.push_back("bneg");
> +    conditionalBranchInstructions.push_back("bneg,a");
> +    conditionalBranchInstructions.push_back("bvs,a");
> +    conditionalBranchInstructions.push_back("ba");
> +    conditionalBranchInstructions.push_back("ba,a");
> +    conditionalBranchInstructions.push_back("bne,a");
> +    conditionalBranchInstructions.push_back("bg,a");
> +    conditionalBranchInstructions.push_back("bge,a");
> +    conditionalBranchInstructions.push_back("bgu,a");
> +    conditionalBranchInstructions.push_back("bcc,a");
> +    conditionalBranchInstructions.push_back("bpos");
> +    conditionalBranchInstructions.push_back("bpos,a");
> +    conditionalBranchInstructions.push_back("bvc,a");
>    Target_sparc::~Target_sparc()
> 2.27.0
> devel mailing list
> devel at rtems.org
