[PATCH] covoar: Add option to create named objdumps
Alex White
alex.white at oarcorp.com
Fri Mar 12 17:07:15 UTC 2021
This adds a new behavior to the -d option which allows the creation of
named objdump outputs in the /tmp directory. This allows the outputs to
be reused on subsequent runs of covoar rather than running objdump
again.
tester/covoar/ObjdumpProcessor.cc | 22 +++++++++++++---------
tester/covoar/ObjdumpProcessor.h | 6 ++++--
tester/covoar/app_common.cc | 10 ++++++++++
tester/covoar/app_common.h | 1 +
tester/covoar/covoar.cc | 23 +++++++++++++++++++----
5 files changed, 47 insertions(+), 15 deletions(-)
diff --git a/tester/covoar/ObjdumpProcessor.cc b/tester/covoar/ObjdumpProcessor.cc
index 9ef2390..fb23ca6 100644
--- a/tester/covoar/ObjdumpProcessor.cc
+++ b/tester/covoar/ObjdumpProcessor.cc
@@ -236,7 +236,8 @@ namespace Coverage {
void ObjdumpProcessor::getFile(
std::string fileName,
rld::process::tempfile& objdumpFile,
- rld::process::tempfile& err
+ rld::process::tempfile& err,
+ bool debug
rld::process::status status;
@@ -245,11 +246,13 @@ namespace Coverage {
fileName };
try
- status = rld::process::execute( TargetInfo->getObjdump(),
- args, objdumpFile.name(), err.name() );
- if ( (status.type != rld::process::status::normal)
- || (status.code != 0) ) {
- throw rld::error( "Objdump error", "generating objdump" );
+ if (!debug || FileIsNewer( fileName.c_str(), objdumpFile.name().c_str() )) {
+ status = rld::process::execute( TargetInfo->getObjdump(),
+ args, objdumpFile.name(), err.name() );
+ if ( (status.type != rld::process::status::normal)
+ || (status.code != 0) ) {
+ throw rld::error( "Objdump error", "generating objdump" );
} catch( rld::error& err )
@@ -325,7 +328,8 @@ namespace Coverage {
void ObjdumpProcessor::load(
ExecutableInfo* const executableInformation,
+ bool debug
std::string currentSymbol = "";
@@ -348,9 +352,9 @@ namespace Coverage {
// Obtain the objdump file.
if ( !executableInformation->hasDynamicLibrary() )
- getFile( executableInformation->getFileName(), objdumpFile, err );
+ getFile( executableInformation->getFileName(), objdumpFile, err, debug );
else
- getFile( executableInformation->getLibraryName(), objdumpFile, err );
+ getFile( executableInformation->getLibraryName(), objdumpFile, err, debug );
while ( true ) {
// Get the line.
diff --git a/tester/covoar/ObjdumpProcessor.h b/tester/covoar/ObjdumpProcessor.h
index c75755d..4dab001 100644
--- a/tester/covoar/ObjdumpProcessor.h
+++ b/tester/covoar/ObjdumpProcessor.h
@@ -103,7 +103,8 @@ namespace Coverage {
void getFile( std::string fileName,
rld::process::tempfile& dmp,
- rld::process::tempfile& err );
+ bool debug = false );
* This method fills the objdumpList list with all the
@@ -122,7 +123,8 @@ namespace Coverage {
void load(
+ bool debug
diff --git a/tester/covoar/app_common.cc b/tester/covoar/app_common.cc
index 8b490ed..0f3c8e2 100644
--- a/tester/covoar/app_common.cc
+++ b/tester/covoar/app_common.cc
@@ -116,3 +116,13 @@ bool ReadUntilFound( FILE *file, const char *line )
} while (1);
+std::string GetFileNameFromPath( const std::string& path )
+ size_t idx = path.rfind('/', path.length());
+ if (idx == std::string::npos) {
+ return "";
+ return path.substr(idx + 1, path.length() - idx);
diff --git a/tester/covoar/app_common.h b/tester/covoar/app_common.h
index ac32bbd..21e8cfa 100644
--- a/tester/covoar/app_common.h
+++ b/tester/covoar/app_common.h
@@ -30,5 +30,6 @@ extern char inputBuffer2[MAX_LINE_LENGTH];
bool FileIsNewer( const char *f1, const char *f2 );
bool FileIsReadable( const char *f1 );
bool ReadUntilFound( FILE *file, const char *line );
+std::string GetFileNameFromPath( const std::string& path );
#endif
diff --git a/tester/covoar/covoar.cc b/tester/covoar/covoar.cc
index bf95cb4..6b2082d 100644
--- a/tester/covoar/covoar.cc
+++ b/tester/covoar/covoar.cc
@@ -373,8 +373,25 @@ int covoar(
exe->setLoadAddress( objdumpProcessor->determineLoadAddress( exe ) );
- // Load the objdump for the symbols in this executable.
- objdumpProcessor->load( exe, objdumpFile, err );
+ if (debug) {
+ std::string name;
+ if ( !exe->hasDynamicLibrary() ) {
+ name = exe->getFileName();
+ } else {
+ name = exe->getLibraryName();
+ name = GetFileNameFromPath( name );
+ name = buildTarget + "-" + name;
+ name.insert( 0, "/tmp/" );
+ rld::process::tempfile namedObjdumpFile( name, ".dmp", true );
+ objdumpProcessor->load( exe, namedObjdumpFile, err, debug );
+ } else {
+ // Load the objdump for the symbols in this executable.
+ objdumpProcessor->load( exe, objdumpFile, err, debug );
@@ -486,8 +503,6 @@ int covoar(
//Leave tempfiles around if debug flag (-d) is enabled.
if ( debug ) {
- objdumpFile.override( "objdump_file" );
- objdumpFile.keep();
err.override( "objdump_exec_log" );
err.keep();
syms.override( "symbols_list" );
2.27.0
