[PATCH] coverage: Fix option processing on FreeBSD
Alex White
alex.white at oarcorp.com
Fri Mar 12 17:18:10 UTC 2021
Covoar uses getopt() to process the command line options. If getopt() is
POSIX-compliant, it will return -1 when it encounters the first
non-option command line argument. It appears that it behaves this way on
FreeBSD, but on Linux getopt() continues to process arguments while
skipping any non-options. This changes the order of arguments passed to
covoar by coverage.py to group all options at the beginning. This allows
hosts with POSIX-compliant getopt() implementations to correctly process
all command line options.
tester/rt/coverage.py | 4 ++--
1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
index a561d26..77e5b69 100644
--- a/tester/rt/coverage.py
+++ b/tester/rt/coverage.py
@@ -361,8 +361,8 @@ class covoar(object):
exe = self._find_covoar()
command = exe + ' -O ' + covoar_result_dir + \
' -p ' + self.project_name + \
- ' ' + self.executables + ' '
- command += self.covoar_cmd
+ ' ' + self.covoar_cmd + ' '
+ command += self.executables
log.notice()
log.notice('Running coverage analysis: %s (%s)' % (set_name, covoar_result_dir))
2.27.0
