All (18) RSB tool failures on rtems6 (details on m68k)
Sat Mar 13 21:43:21 UTC 2021
Hi
Most (all?) of the targets for rtems6 fail to build right now. I decided to
pick on the m68k and it looks like a mismatch between gcc and as on
arguments. These should all be on the build@ list since Chris increased the
allowed size of posts.
Does anyone know what we might have out of sync?
configure:3804:
/home/joel/rtems-cron-6/rtems-source-builder/rtems/build/m68k-rtems6-gcc-6051af8-newlib-d10d0d9-x86_64-linux-gnu-1/build/./gcc/xgcc
-B/home/joel/rtems-cron-6/rtems-source-builder/rtems/build/m68k-rtems6-gcc-6051af8-newlib-d10d0d9-x86_64-linux-gnu-1/build/./gcc/
-nostdinc
-B/home/joel/rtems-cron-6/rtems-source-builder/rtems/build/m68k-rtems6-gcc-6051af8-newlib-d10d0d9-x86_64-linux-gnu-1/build/m68k-rtems6/newlib/
-isystem
/home/joel/rtems-cron-6/rtems-source-builder/rtems/build/m68k-rtems6-gcc-6051af8-newlib-d10d0d9-x86_64-linux-gnu-1/build/m68k-rtems6/newlib/targ-include
-isystem
/home/joel/rtems-cron-6/rtems-source-builder/rtems/build/m68k-rtems6-gcc-6051af8-newlib-d10d0d9-x86_64-linux-gnu-1/gnu-mirror-gcc-6051af8/newlib/libc/include
-B/home/joel/rtems-cron-6/tools/6/m68k-rtems6/bin/
-B/home/joel/rtems-cron-6/tools/6/m68k-rtems6/lib/ -isystem
/home/joel/rtems-cron-6/tools/6/m68k-rtems6/include -isystem
/home/joel/rtems-cron-6/tools/6/m68k-rtems6/sys-include    -c -g -O2
 conftest.c >&5
/home/joel/rtems-cron-6/rtems-source-builder/rtems/build/m68k-rtems6-gcc-6051af8-newlib-d10d0d9-x86_64-linux-gnu-1/build/./gcc/as:
line 106: exec: -m: invalid option
exec: usage: exec [-cl] [-a name] [command [arguments ...]] [redirection
configure:3808: $? = 1
configure: failed program was:
| /* confdefs.h */
| #define PACKAGE_NAME "GNU C Runtime Library"
| #define PACKAGE_TARNAME "libgcc"
| #define PACKAGE_VERSION "1.0"
| #define PACKAGE_STRING "GNU C Runtime Library 1.0"
| #define PACKAGE_BUGREPORT ""
| #define PACKAGE_URL "http://www.gnu.org/software/libgcc/"
| /* end confdefs.h.  */
| int
| main ()
|   return 0;
configure:3822: error: in
`/home/joel/rtems-cron-6/rtems-source-builder/rtems/build/m68k-rtems6-gcc-6051af8-newlib-d10d0d9-x86_64-linux-gnu-1/build/m68k-rtems6/libgcc':
I also checked the sparc and it was a different argument to as and the as
it invoked in the tree was a shell script. I don't know if that was right
or wrong.
I don't think this is failing on Ubuntu or FreeBSD. This is on CentOS 7.
I going to try
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210313/2a7fe2bf/attachment-0001.html>
