[PATCH] rtems-examples: Add CoreMark Benchmark
Joel Sherrill
joel.sherrill at gmail.com
Sat Mar 13 21:38:06 UTC 2021
I don't see any RTEMS specific instructions added. Especially
since I think you need them to deal with the submodule.
What happens when you haven't dealt with the submodule? Is the
error reasonable? I would think a directory is missing and the waf
build will die.
I am thrilled to see these added. Any advice for how we can use
these in the project. Compare architectures? RTEMS versions?
--joel
On Sat, Mar 13, 2021 at 1:50 AM Hesham Almatary <
hesham.almatary at cl.cam.ac.uk> wrote:
> CoreMark's primary goals are simplicity and providing a method for
> testing only a processor's core features. It is used primarily here as
> a performance benchmark.
> Built and tested for RISC-V rv64imafdc_medany on QEMU and HW
> .gitmodules | 3 +++
> benchmarks/coremark/coremark | 1 +
> benchmarks/coremark/wscript | 50 ++++++++++++++++++++++++++++++++++++
> benchmarks/wscript | 2 +-
> 4 files changed, 55 insertions(+), 1 deletion(-)
> create mode 160000 benchmarks/coremark/coremark
> create mode 100644 benchmarks/coremark/wscript
> diff --git a/.gitmodules b/.gitmodules
> index ae86e49..d7e52b9 100644
> --- a/.gitmodules
> +++ b/.gitmodules
> @@ -1,3 +1,6 @@
> [submodule "rtems_waf"]
> path = rtems_waf
> url = git://git.rtems.org/rtems_waf.git
> +[submodule "benchmarks/coremark/coremark"]
> + path = benchmarks/coremark/coremark
> + url = git at github.com:eembc/coremark.git
> diff --git a/benchmarks/coremark/coremark b/benchmarks/coremark/coremark
> new file mode 160000
> index 0000000..1541482
> --- /dev/null
> +++ b/benchmarks/coremark/coremark
> @@ -0,0 +1 @@
> +Subproject commit 1541482bf3e6ef7f5c69f5be76b14537b60833d0
> diff --git a/benchmarks/coremark/wscript b/benchmarks/coremark/wscript
> new file mode 100644
> index 0000000..2ec5f1e
> --- /dev/null
> +++ b/benchmarks/coremark/wscript
> @@ -0,0 +1,50 @@
> +# SPDX-License-Identifier: BSD-2-Clause
> +# Copyright (c) 2021 Hesham Almatary
> +# This software was developed by SRI International and the University of
> +# Cambridge Computer Laboratory (Department of Computer Science and
> +# Technology) under DARPA contract HR0011-18-C-0016 ("ECATS"), as part of
> the
> +# DARPA SSITH research programme.
> +# Redistribution and use in source and binary forms, with or without
> +# modification, are permitted provided that the following conditions
> +# are met:
> +# 1. Redistributions of source code must retain the above copyright
> +# notice, this list of conditions and the following disclaimer.
> +# 2. Redistributions in binary form must reproduce the above copyright
> +# notice, this list of conditions and the following disclaimer in the
> +# documentation and/or other materials provided with the distribution.
> +# THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
> +# ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> +# ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
> +# FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> CONSEQUENTIAL
> +# DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
> +# OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
> +# HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
> STRICT
> +# LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY
> WAY
> +# OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
> +# SUCH DAMAGE.
> +import rtems_waf.rtems as rtems
> +def build(bld):
> + rtems.build(bld)
> + bld(features = 'c cprogram',
> + target = 'coremark.bin',
> + includes = ['coremark/', 'coremark/posix/'],
> + source = ['coremark/rtems/init.c', 'coremark/posix/core_portme.c',
> + 'coremark/core_list_join.c', 'coremark/core_main.c',
> + 'coremark/core_matrix.c', 'coremark/core_state.c',
> + 'coremark/core_util.c'],
> + defines = [
> + # FLAGS_STR is used within CoreMark to print the compiler flags
> used
> + 'FLAGS_STR="'+' '.join([str(flag) for flag in bld.env.CFLAGS])+'"'
> diff --git a/benchmarks/wscript b/benchmarks/wscript
> index 12741e7..0947060 100644
> --- a/benchmarks/wscript
> +++ b/benchmarks/wscript
> @@ -7,4 +7,4 @@ import rtems_waf.rtems as rtems
> def build(bld):
> bld.recurse('nbench')
> + bld.recurse('coremark')
> 2.25.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210313/1da69501/attachment-0001.html>
