[PATCH 1/1] Hello World - Ida's proof to work on rtems
Ida Delphine
idadelm at gmail.com
Sun Mar 14 19:05:14 UTC 2021
Thanks for the feedback!
On Sun, Mar 14, 2021 at 5:32 PM Gedare Bloom <gedare at rtems.org> wrote:
> Hi Ida,
> This is acceptable for your proof and no further revisions are
> required, but please see my notes below:
> On Fri, Mar 12, 2021 at 9:13 PM Ida Delphine <idadelm at gmail.com> wrote:
> > From: Meh Mbeh Ida Delphine <idadelm at gmail.com>
> Author info looks good, thanks.
> > Modified rtems/testsuites/samples/hello/init.c to prove I can work on
> the RTEMS project for GSoC.
> See https://devel.rtems.org/wiki/Developer/Git#GitCommits for more
> about preparing "real commits" in the future. This one is acceptable
> for the proof.
> (We need to merge that text from
> https://devel.rtems.org/wiki/Developer/Git#GitCommits into a suitable
> subsection in
> https://docs.rtems.org/branches/master/eng/vc-users.html#creating-a-patch
> someday.)
> > testsuites/samples/hello/init.c | 2 +-
> > 1 file changed, 1 insertion(+), 1 deletion(-)
> > diff --git a/testsuites/samples/hello/init.c
> b/testsuites/samples/hello/init.c
> > index 34ded37c55..fa581fd447 100644
> > --- a/testsuites/samples/hello/init.c
> > +++ b/testsuites/samples/hello/init.c
> > @@ -22,7 +22,7 @@ static rtems_task Init(
> > rtems_print_printer_fprintf_putc(&rtems_test_printer);
> > TEST_BEGIN();
> > - printf( "Hello World\n" );
> > + printf( "Hello World, I'm Ida Deslphine and this is th main proof I
> can officially work on the RTEMS Project for GSoC. I'm so excited. Thank
> you all for the help you rendered when I ran into several errors!\n" );
> The message is great! :) Now you can start to see why we make this
> task part of our proposal preparation!
> Note that our code style adheres to a maximum of 80 characters per
> line: https://docs.rtems.org/branches/master/eng/coding.html
> We are still working toward automated code style checking (which is by
> the way a GSoC project: https://devel.rtems.org/ticket/3860 that does
> not require strong C/asm skills).
> Please add your info to
> https://devel.rtems.org/wiki/GSoC/2021#StudentsProposals
> I guess so far none of the other students who did the proof have added
> themselves, but feel free to be first! If you need help on the
> formatting, you can go in the prior year's GSoC and see how the table
> is set up. (Click Edit on the bottom of the page to find the wiki
> source.)
> Gedare
> > TEST_END();
> > rtems_test_exit( 0 );
> > 2.25.1
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210314/d83ed01c/attachment-0001.html>
