[PATCH v2 1/4] covoar/reports: Add new statistics to summary
Alex White
alex.white at oarcorp.com
Mon Mar 15 22:09:20 UTC 2021
The following new statistics have been added to the summary report:
number of unreferenced symbols, total branch paths found, number of
branch paths not executed, and percentage of branch paths covered.
tester/covoar/DesiredSymbols.cc | 10 +++++++
tester/covoar/DesiredSymbols.h | 24 ++++++++++++++++-
tester/covoar/ReportsBase.cc | 46 +++++++++++++++++++++++++++------
tester/rt/coverage.py | 33 +++++++++++++----------
4 files changed, 91 insertions(+), 22 deletions(-)
diff --git a/tester/covoar/DesiredSymbols.cc b/tester/covoar/DesiredSymbols.cc
index c97b25c..ffc4f86 100644
--- a/tester/covoar/DesiredSymbols.cc
+++ b/tester/covoar/DesiredSymbols.cc
@@ -175,6 +175,8 @@ namespace Coverage {
s.second.stats.uncoveredBytes++;
+ } else {
+ stats.unreferencedSymbols++;
@@ -470,10 +472,18 @@ namespace Coverage {
return stats.branchesNeverTaken;
+ uint32_t DesiredSymbols::getNumberBranchesNotExecuted( void ) const {
+ return stats.branchesNotExecuted;
uint32_t DesiredSymbols::getNumberUncoveredRanges( void ) const {
return stats.uncoveredRanges;
+ uint32_t DesiredSymbols::getNumberUnreferencedSymbols( void ) const {
+ return stats.unreferencedSymbols;
bool DesiredSymbols::isDesired (
const std::string& symbolName
) const
diff --git a/tester/covoar/DesiredSymbols.h b/tester/covoar/DesiredSymbols.h
index 367ca95..5cf96e9 100644
--- a/tester/covoar/DesiredSymbols.h
+++ b/tester/covoar/DesiredSymbols.h
@@ -82,6 +82,11 @@ namespace Coverage {
int uncoveredRanges;
+ * This member variable contains the total number of unreferenced symbols.
+ int unreferencedSymbols;
* This method returns the percentage of uncovered instructions.
@@ -109,7 +114,8 @@ namespace Coverage {
sizeInInstructions(0),
uncoveredBytes(0),
uncoveredInstructions(0),
- uncoveredRanges(0)
+ uncoveredRanges(0),
+ unreferencedSymbols(0)
@@ -278,6 +284,14 @@ namespace Coverage {
uint32_t getNumberBranchesNeverTaken( void ) const;
+ * This method returns the total number of branches not executed
+ * for all analyzed symbols.
+ * @return Returns the total number of branches not executed
+ uint32_t getNumberBranchesNotExecuted( void ) const;
* This method returns the total number of uncovered ranges
@@ -286,6 +300,14 @@ namespace Coverage {
uint32_t getNumberUncoveredRanges( void ) const;
+ * This method returns the total number of unreferenced symbols
+ * @return Returns the total number of unreferenced symbols
+ uint32_t getNumberUnreferencedSymbols( void ) const;
* This method returns an indication of whether or not the specified
* symbol is a symbol to analyze.
diff --git a/tester/covoar/ReportsBase.cc b/tester/covoar/ReportsBase.cc
index 0244601..0be5567 100644
--- a/tester/covoar/ReportsBase.cc
+++ b/tester/covoar/ReportsBase.cc
@@ -441,6 +441,7 @@ void ReportsBase::WriteSummaryReport(
Coverage::DesiredSymbols::symbolSet_t::iterator itr;
uint32_t notExecuted = 0;
double percentage;
+ double percentageBranches;
Coverage::CoverageMapBase* theCoverageMap;
uint32_t totalBytes = 0;
FILE* report;
@@ -475,13 +476,26 @@ void ReportsBase::WriteSummaryReport(
percentage /= (double) totalBytes;
percentage *= 100.0;
- fprintf( report, "Bytes Analyzed : %d\n", totalBytes );
- fprintf( report, "Bytes Not Executed : %d\n", notExecuted );
- fprintf( report, "Percentage Executed : %5.4g\n", 100.0 - percentage );
- fprintf( report, "Percentage Not Executed : %5.4g\n", percentage );
+ percentageBranches = (double) (
+ SymbolsToAnalyze->getNumberBranchesAlwaysTaken() +
+ SymbolsToAnalyze->getNumberBranchesNeverTaken() +
+ (SymbolsToAnalyze->getNumberBranchesNotExecuted() * 2)
+ percentageBranches /= (double) SymbolsToAnalyze->getNumberBranchesFound() * 2;
+ percentageBranches *= 100.0;
+ fprintf( report, "Bytes Analyzed : %d\n", totalBytes );
+ fprintf( report, "Bytes Not Executed : %d\n", notExecuted );
+ fprintf( report, "Percentage Executed : %5.4g\n", 100.0 - percentage );
+ fprintf( report, "Percentage Not Executed : %5.4g\n", percentage );
fprintf(
report,
- "Uncovered ranges found : %d\n",
+ "Unreferenced Symbols : %d\n",
+ SymbolsToAnalyze->getNumberUnreferencedSymbols()
+ fprintf(
+ report,
+ "Uncovered ranges found : %d\n\n",
SymbolsToAnalyze->getNumberUncoveredRanges()
if ((SymbolsToAnalyze->getNumberBranchesFound() == 0) ||
@@ -490,14 +504,20 @@ void ReportsBase::WriteSummaryReport(
} else {
fprintf(
report,
- "Total branches found : %d\n",
+ "Total conditional branches found : %d\n",
fprintf(
report,
- "Uncovered branches found : %d\n",
+ "Total branch paths found : %d\n",
+ SymbolsToAnalyze->getNumberBranchesFound() * 2
+ fprintf(
+ report,
+ "Uncovered branch paths found : %d\n",
- SymbolsToAnalyze->getNumberBranchesNeverTaken()
fprintf(
report,
@@ -509,6 +529,16 @@ void ReportsBase::WriteSummaryReport(
" %d branches never taken\n",
+ fprintf(
+ report,
+ " %d branch paths not executed\n",
+ SymbolsToAnalyze->getNumberBranchesNotExecuted() * 2
+ fprintf(
+ report,
+ "Percentage branch paths covered : %4.4g\n",
+ 100.0 - percentageBranches
diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
index e2a5161..8d176c3 100644
--- a/tester/rt/coverage.py
+++ b/tester/rt/coverage.py
@@ -56,6 +56,7 @@ class summary:
self.bytes_not_executed = 0
self.percentage_executed = 0.0
self.percentage_not_executed = 100.0
+ self.unreferenced_symbols = 0
self.ranges_uncovered = 0
self.branches_uncovered = 0
self.branches_total = 0
@@ -74,7 +75,10 @@ class summary:
self.bytes_not_executed = self._get_next_with_colon(summary_file)
self.percentage_executed = self._get_next_with_colon(summary_file)
self.percentage_not_executed = self._get_next_with_colon(summary_file)
+ self.unreferenced_symbols = self._get_next_with_colon(summary_file)
self.ranges_uncovered = self._get_next_with_colon(summary_file)
+ summary_file.readline()
self.branches_total = self._get_next_with_colon(summary_file)
self.branches_uncovered = self._get_next_with_colon(summary_file)
self.branches_always_taken = self._get_next_without_colon(summary_file)
@@ -153,6 +157,7 @@ class report_gen_html:
+ '</td>' + os.linesep
row += ' <td>' + summary.bytes_analyzed + '</td>' + os.linesep
row += ' <td>' + summary.bytes_not_executed + '</td>' + os.linesep
+ row += ' <td>' + summary.unreferenced_symbols + '</td>' + os.linesep
row += ' <td>' + summary.ranges_uncovered + '</td>' + os.linesep
row += ' <td>' + summary.percentage_executed + '%</td>' + os.linesep
row += ' <td>' + summary.percentage_not_executed + '%</td>' + os.linesep
@@ -168,19 +173,21 @@ class report_gen_html:
def _header_row(self):
row = "<tr>" + os.linesep
- row += " <th> Symbols set name </th>" + os.linesep
- row += " <th> Index file </th>" + os.linesep
- row += " <th> Summary file </th>" + os.linesep
- row += " <th> Bytes analyzed </th>" + os.linesep
- row += " <th> Bytes not executed </th>" + os.linesep
- row += " <th> Uncovered ranges </th>" + os.linesep
- row += " <th> Percentage covered </th>" + os.linesep
- row += " <th> Percentage uncovered </th>" + os.linesep
- row += " <th> Instruction coverage </th>" + os.linesep
- row += " <th> Branches uncovered </th>" + os.linesep
- row += " <th> Branches total </th>" + os.linesep
- row += " <th> Branches covered percentage </th>" + os.linesep
- row += " <th> Branches coverage </th>" + os.linesep
+ rowAttributes = "class=\"table-sortable:default table-sortable\" title=\"Click to sort\""
+ row += " <th " + rowAttributes + "> Symbols set name </th>" + os.linesep
+ row += " <th " + rowAttributes + "> Index file </th>" + os.linesep
+ row += " <th " + rowAttributes + "> Summary file </th>" + os.linesep
+ row += " <th " + rowAttributes + "> Bytes analyzed </th>" + os.linesep
+ row += " <th " + rowAttributes + "> Bytes not executed </th>" + os.linesep
+ row += " <th " + rowAttributes + "> Unreferenced symbols </th>" + os.linesep
+ row += " <th " + rowAttributes + "> Uncovered ranges </th>" + os.linesep
+ row += " <th " + rowAttributes + "> Percentage covered </th>" + os.linesep
+ row += " <th " + rowAttributes + "> Percentage uncovered </th>" + os.linesep
+ row += " <th " + rowAttributes + "> Instruction coverage </th>" + os.linesep
+ row += " <th " + rowAttributes + "> Branches uncovered </th>" + os.linesep
+ row += " <th " + rowAttributes + "> Branches total </th>" + os.linesep
+ row += " <th " + rowAttributes + "> Branches covered percentage </th>" + os.linesep
+ row += " <th " + rowAttributes + "> Branch coverage </th>" + os.linesep
row += "</tr>"
self.number_of_columns = row.count('<th>')
return row
2.27.0
