[PATCH 1/2] covoar/CoverageReaderQEMU: Fix infinite loop
Mon Mar 15 22:58:04 UTC 2021
On 16/3/21 9:11 am, Gedare Bloom wrote:
> On Mon, Mar 15, 2021 at 3:34 PM Alex White <alex.white at oarcorp.com
> <mailto:alex.white at oarcorp.com>> wrote:
>     I honestly can't remember why I changed 1024 to 20,000.
>     I've looked back at that code and changed it back to 1024 without any
>     issues. I think I might have missed that this is all happening in a loop,
>     and at one point during a (long) debugging session I convinced myself that
>     it wasn't reading all of the entries.
>     At least that's the most rational explanation I can think up for that
>     particular change. 😊
>     If I revert ENTRIES from 20000 back to 1024, are we satisfied to leave the
>     "entries" array as-is?
> I think that Chris' main points here are that, as you get covoar working again
> and cleaning it up, it should be made more C++ (and less C).
Thanks Gedare, yes I am asking if this could be considered. A total conversion
is not realistic and would be asking too much but my hope is making changes in
small pieces can be done. Some changes will requiring new C++ skills but that
should be thought of as a fun challenge.
In this case I think changing to a vector would be a good thing for 1024 entries
but we had 1024 in the code previously and it was fine so I am also OK if it
left that way.
