[PATCH 1/5] hexdump-parse.c: Fix Resource leak (CID #26032)
Joel Sherrill
joel at rtems.org
Mon Mar 15 23:07:17 UTC 2021
On Mon, Mar 15, 2021 at 6:01 PM Chris Johns <chrisj at rtems.org> wrote:
> On 16/3/21 6:55 am, Joel Sherrill wrote:
> > On Mon, Mar 15, 2021 at 2:46 PM Gedare Bloom <gedare at rtems.org
> > <mailto:gedare at rtems.org>> wrote:
> > On Sun, Mar 14, 2021 at 8:27 PM Chris Johns <chrisj at rtems.org
> > <mailto:chrisj at rtems.org>> wrote:
> > > On 13/3/21 2:18 am, Ryan Long wrote:
> > > > CID 26032: Resource leak in rtems_shell_hexdump_rewrite().
> > > > Closes #4296
> > > > cpukit/libmisc/shell/hexdump-parse.c | 3 +++
> > > > 1 file changed, 3 insertions(+)
> > > > diff --git a/cpukit/libmisc/shell/hexdump-parse.c
> > b/cpukit/libmisc/shell/hexdump-parse.c
> > > > index 88b9d56..5b56bbf 100644
> > > > --- a/cpukit/libmisc/shell/hexdump-parse.c
> > > > +++ b/cpukit/libmisc/shell/hexdump-parse.c
> > > > @@ -462,6 +462,9 @@ isint2:
> > switch(fu->bcnt) {
> > > > (void)printf("\n");
> > > > #endif
> > > > +#ifdef __rtems__
> > > > + free(nextpr);
> > > > +#endif
> > > I know this has not been done in imported code in rtems.git before
> but
> > should we
> > > adopt the libbsd standard of adding /* __rtems__ */ to the #else
> and #endif?
> > Probably, but we also clone-and-own this shell/ code, and we should
> > not bother with these #ifdefs in there. I think I have said this 3
> > times this past week about shell/. The upstream does not want our
> > changes, and we don't import from them anymore.
> > Some of these files have massive changes and some don't. Ryan and
> > I looked at main_cp.c and it had at least 40 revisions since the version
> > we have. The same Coverity issue appeared to be present but the variable
> > names were changed and much clearer.
> Yes.
> > Chris imported this code initially. I'll trust his ruling on this since
> I assume
> > he is likely to either be the one to update it eventually or have to
> help someone
> > a lot. :)
> If the code was updated I would use the libbsd way of handing it. It has
> been
> proven to work.
> > And some of it is close enough that the ifdef's are worth it. Some
> isn't.
> > Hard call on the overall value.
> For the existing code it is hard to call. If I was starting again I would
> say we
> had to support a clean separation.
I assume you would checkout the original version and diff it. But would the
ifdef rtems ease the burden any?
I tend to like going with them otherwise, we have some files we do it
on and others we don't.
--joel
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210315/b2094a8d/attachment-0001.html>
