[PATCH rtems-docs v2 1/6] rtems-docs: Update installation prefix
Ida Delphine
idadelm at gmail.com
Tue Mar 16 08:15:10 UTC 2021
user/start/prefixes.rst | 8 ++++----
1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/user/start/prefixes.rst b/user/start/prefixes.rst
index 67255d0..826ce85 100644
--- a/user/start/prefixes.rst
+++ b/user/start/prefixes.rst
@@ -40,7 +40,7 @@ applications and systems.
You build and install the tool suite with the :ref:`RTEMS Source Builder (RSB)
<RSB>`. By default, the RSB will start the prefix path with a host operating
system specific path plus :file:`rtems`, and the RTEMS version, e.g.
-:file:`/opt/rtems/5` on Linux, and :file:`/usr/local/rtems/5` on FreeBSD and
+:file:`/opt/rtems/6` on Linux, and :file:`/usr/local/rtems/6` on FreeBSD and
macOS. Placing the RTEMS version number in the path lets you manage and
migrate RTEMS versions as they are released.
@@ -50,10 +50,10 @@ make sure that your normal user has sufficient privileges to create files and
directories under the prefix. For example, you can create a directory
:file:`/opt/rtems` and give it to a developer group with read, write, and
execute permissions. Alternatively, you can choose a prefix in your home
-directory, e.g. :file:`$HOME/rtems/5` or with a project-specific component
-:file:`$HOME/project-x/rtems/5`. For more ideas, see the :ref:`project
+directory, e.g. :file:`$HOME/rtems/6` or with a project-specific component
+:file:`$HOME/project-x/rtems/6`. For more ideas, see the :ref:`project
sandboxing <ProjectSandboxing>` section. In this quick start chapter, we will
-choose :file:`$HOME/quick-start/rtems/5` for the RTEMS tool suite prefix.
+choose :file:`$HOME/quick-start/rtems/6` for the RTEMS tool suite prefix.
.. warning::
2.25.1
