[PATCH rtems-docs v2 3/6] rtems-docs: Edit command to install toolsuite
Ida Delphine idadelm at gmail.com
Tue Mar 16 08:15:12 UTC 2021
Edit edit sample output of tool suite installation.
Edit command to check if C cross compiler works and sample output of this command.
 user/start/tools.rst | 26 +++++++++++++-------------
 1 file changed, 13 insertions(+), 13 deletions(-)
diff --git a/user/start/tools.rst b/user/start/tools.rst
index baa2387..9a915ab 100644
--- a/user/start/tools.rst
+++ b/user/start/tools.rst
@@ -12,7 +12,7 @@ Install the Tool Suite
 You have chosen an installation prefix, the BSP to build, the tool's
 architecure and prepared the source for the RSB in the previous sections.  We
-have chosen :file:`$HOME/quick-start/rtems/5` as the installation prefix, the
+have chosen :file:`$HOME/quick-start/rtems/6` as the installation prefix, the
 ``erc32`` BSP and the SPARC architecture name of ``sparc-rtems5``, and unpacked
 the RSB source in :file:`$HOME/quick-start/src`.
@@ -25,7 +25,7 @@ Build and install the tool suite:
 .. code-block:: none
     cd $HOME/quick-start/src/rsb/rtems
-    ../source-builder/sb-set-builder --prefix=$HOME/quick-start/rtems/5 5/rtems-sparc
+    ../source-builder/sb-set-builder --prefix=$HOME/quick-start/rtems/6 6/rtems-sparc
 This command should output something like this (omitted lines are denoted by
 ...). The build host appears as part of the name of the package being
@@ -33,19 +33,19 @@ built. The name you see may vary depending on the host you are using:
-    RTEMS Source Builder - Set Builder, 5.1.0
-    Build Set: 5/rtems-sparc
+    RTEMS Source Builder - Set Builder, 6
+    Build Set: 6/rtems-sparc
     config: tools/rtems-binutils-2.34.cfg
-    package: sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1
-    building: sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1
-    sizes: sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1: 305.866MB (installed: 29.966MB)
-    cleaning: sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1
+    package: sparc-rtems6=-binutils-2.34-x86_64-freebsd12.1-1
+    building: sparc-rtems6-binutils-2.34-x86_64-freebsd12.1-1
+    sizes: sparc-rtems6-binutils-2.34-x86_64-freebsd12.1-1: 305.866MB (installed: 29.966MB)
+    cleaning: sparc-rtems6-binutils-2.34-x86_64-freebsd12.1-1
     reporting: tools/rtems-binutils-2.34.cfg -> sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1.txt
     reporting: tools/rtems-binutils-2.34.cfg -> sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1.xml
     config: tools/rtems-gcc-7.5.0-newlib-fbaa096.cfg
-    package: sparc-rtems5-gcc-7.5.0-newlib-fbaa096-x86_64-freebsd12.1-1
-    building: sparc-rtems5-gcc-7.5.0-newlib-fbaa096-x86_64-freebsd12.1-1
+    package: sparc-rtems6-gcc-7.5.0-newlib-fbaa096-x86_64-freebsd12.1-1
+    building: sparc-rtems6-gcc-7.5.0-newlib-fbaa096-x86_64-freebsd12.1-1
     Build Sizes: usage: 5.684GB total: 1.112GB (sources: 143.803MB, patches: 21.348KB, installed 995.188MB)
     Build Set: Time 0:21:35.626294
@@ -55,7 +55,7 @@ works with the following command:
-    $HOME/quick-start/rtems/5/bin/sparc-rtems5-gcc --version
+    $HOME/quick-start/rtems/6/bin/sparc-rtems6-gcc --version
 This command should output something like below.  The version informtion helps
 you to identify the exact sources used to build the cross compiler of your
@@ -69,8 +69,8 @@ source code used.
-    sparc-rtems5-gcc (GCC) 7.5.0 20191114 (RTEMS 5, RSB 5.1.0, Newlib fbaa096)
-    Copyright (C) 2017 Free Software Foundation, Inc.
+    sparc-rtems6-gcc (GCC) 10.2.1 20210309 (RTEMS 6, RSB 5e449fb5c2cb6812a238f9f9764fd339cbbf05c2, Newlib d10d0d9)
+    Copyright (C) 2020 Free Software Foundation, Inc.
     This is free software; see the source for copying conditions.  There is NO
     warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
2.25.1
