[PATCH] sp14: Fix for SMP or robust thread dispatch
Kinsey Moore
kinsey.moore at oarcorp.com
Tue Mar 16 12:21:30 UTC 2021
This fixes the issues on AArch64 and ARM, thanks!
Kinsey
-----Original Message-----
From: devel <devel-bounces at rtems.org> On Behalf Of Sebastian Huber
Sent: Tuesday, March 16, 2021 06:20
To: devel at rtems.org
Subject: [PATCH] sp14: Fix for SMP or robust thread dispatch
Close #4343.
testsuites/sptests/sp14/task1.c | 5 +++++
1 file changed, 5 insertions(+)
diff --git a/testsuites/sptests/sp14/task1.c b/testsuites/sptests/sp14/task1.c
index e1b80c71b4..07657272dc 100644
--- a/testsuites/sptests/sp14/task1.c
+++ b/testsuites/sptests/sp14/task1.c
@@ -36,8 +36,13 @@ rtems_task Task_1(
rtems_mode previous_mode;
rtems_status_code status;
+#if defined(RTEMS_SMP) || CPU_ENABLE_ROBUST_THREAD_DISPATCH == TRUE
+ puts( "TA1 - rtems_signal_catch - RTEMS_INTERRUPT_LEVEL( 0 )" );
+ status = rtems_signal_catch( Process_asr, RTEMS_INTERRUPT_LEVEL(0) );
+#else
puts( "TA1 - rtems_signal_catch - RTEMS_INTERRUPT_LEVEL( 3 )" );
status = rtems_signal_catch( Process_asr, RTEMS_INTERRUPT_LEVEL(3) );
+#endif
directive_failed( status, "rtems_signal_catch" );
puts( "TA1 - rtems_signal_send - RTEMS_SIGNAL_16 to self" );
2.26.2
devel mailing list
devel at rtems.org
http://lists.rtems.org/mailman/listinfo/devel
