[PATCH 3/3] rtems: Improve semaphore create error checks
Tue Mar 16 13:57:56 UTC 2021
Do not mix checks for different error indicators (RTEMS_NOT_DEFINED and
RTEMS_INVALID_NUMBER).  This simplifies the specification of
rtems_semaphore_create().
 cpukit/rtems/src/semcreate.c | 10 ++++------
 1 file changed, 4 insertions(+), 6 deletions(-)
diff --git a/cpukit/rtems/src/semcreate.c b/cpukit/rtems/src/semcreate.c
index 0246c91bc9..b58ea0199f 100644
--- a/cpukit/rtems/src/semcreate.c
+++ b/cpukit/rtems/src/semcreate.c
@@ -72,12 +72,6 @@ rtems_status_code rtems_semaphore_create(
   if ( maybe_global == RTEMS_COUNTING_SEMAPHORE ) {
     variant = SEMAPHORE_VARIANT_COUNTING;
-  } else if ( count > 1 ) {
-     * The remaining variants are all binary semphores, thus reject an invalid
-     * count value.
-    return RTEMS_INVALID_NUMBER;
   } else if ( maybe_global == RTEMS_SIMPLE_BINARY_SEMAPHORE ) {
     variant = SEMAPHORE_VARIANT_SIMPLE_BINARY;
   } else if ( maybe_global == RTEMS_BINARY_SEMAPHORE ) {
@@ -109,6 +103,10 @@ rtems_status_code rtems_semaphore_create(
     return RTEMS_NOT_DEFINED;
+  if ( count > 1 && variant != SEMAPHORE_VARIANT_COUNTING ) {
+    return RTEMS_INVALID_NUMBER;
   the_semaphore = _Semaphore_Allocate();
   if ( !the_semaphore ) {
2.26.2
