[PATCH 2/5] rtems-fdt.c: Fix Resource leak (CID #1437645)
Gedare Bloom
gedare at rtems.org
Tue Mar 16 15:14:26 UTC 2021
On Tue, Mar 16, 2021 at 1:15 AM Niteesh G. S. <niteesh.gs at gmail.com> wrote:
> On Tue, 16 Mar 2021, 1:37 am Gedare Bloom, <gedare at rtems.org> wrote:
>> This one looks ok to me, Niteesh?
> +1
> The below question is not related to this patch.
> Out of interest, I started going through the code and I am a bit confused in the following statement
> https://git.rtems.org/rtems/tree/cpukit/libmisc/rtems-fdt/rtems-fdt.c#n574
> This else block is reached when the FDT blob is not compressed, in this case the size variable is set to the file size since this is raw data.
> In the while loop, we are looping on size, but we never modify the size. I think, line 583 should be
> size -= r;
> Instead of
> r -= size;
> Is this a bug??
> Or am I missing something?
it looks weird to me too. Chris?
> PS: I am really sorry, If the formatting looks off I wrote this mail using my mobile.
> Thanks
> Niteesh
>> On Fri, Mar 12, 2021 at 8:19 AM Ryan Long <ryan.long at oarcorp.com> wrote:
>> > CID 1437645: Resource leak in rtems_fdt_load().
>> > Closes #4297
>> > cpukit/libmisc/rtems-fdt/rtems-fdt.c | 1 +
>> > 1 file changed, 1 insertion(+)
>> > diff --git a/cpukit/libmisc/rtems-fdt/rtems-fdt.c b/cpukit/libmisc/rtems-fdt/rtems-fdt.c
>> > index 0ea3653..5bb7ce0 100644
>> > --- a/cpukit/libmisc/rtems-fdt/rtems-fdt.c
>> > +++ b/cpukit/libmisc/rtems-fdt/rtems-fdt.c
>> > @@ -611,6 +611,7 @@ rtems_fdt_load (const char* filename, rtems_fdt_handle* handle)
>> > return fe;
>> > + close (bf);
>> > return 0;
>> > 1.8.3.1
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
