[PATCH rtems-docs] eng/vc-users: Set up patch message with repo name
Tue Mar 16 19:08:10 UTC 2021
Hi Ida,
I have built and checked the output, it looks good but I did make a
tiny change to remove HEAD^ with ... to be a bit non-specific, and
fixed a typo in your commit message. I would however like you to
confirm that you can build the docs :) as your next step, it is best
to confirm that patches you send build properly. Pull the updated repo
and build it to confirm you see your change properly made.
When I applied this patch, I got
warning: 2 lines add whitespace errors.
I have fixed those two lines where there was a whitespace character at
the end of the line. Although that is not such a big deal in the docs,
we prefer to avoid those trailing spaces in code. Keep that in mind.
Maybe someday we'll have a proper style checker to help ;)
Congratulations on your first contribution :)
Gedare
On Tue, Mar 16, 2021 at 12:31 PM Ida Delphine <idadelm at gmail.com> wrote:
> From: Meh Mbeh Ida Delphine <idadelm at gmail.com>
> Added instructions on how to set up a patch messahe with a repo name.
> Author:    Meh Mbeh Ida Delphine <idadelm at gmail.com>
> Date:      Tue Mar 16 19:11:23 2021 +0100
>  eng/vc-users.rst | 8 ++++++++
>  1 file changed, 8 insertions(+)
> diff --git a/eng/vc-users.rst b/eng/vc-users.rst
> index 31de516..772019e 100644
> --- a/eng/vc-users.rst
> +++ b/eng/vc-users.rst
> @@ -458,6 +458,14 @@ specify a version number for your patch, for example, use
>  to indicate the second version of a patch, ``-v3`` for a third, and so forth.
> +Also, in order to create a patch specifying the repo name in the patch message,
> +you should use the``--subject-prefix`` flag. For example, if contributing to
> +the rtems-docs repo, use
> +.. code-block:: shell
> +  git format-patch HEAD^ --subject-prefix="PATCH rtems-docs"
>  Patches created using ``git format-patch`` are formatted so they can be emailed
>  and rely on having Git configured with your name and email address, for example
> 2.25.1
> devel mailing list
> devel at rtems.org
