[PATCH v3] covoar: Handle periods in symbols from objdump
Alex White alex.white at oarcorp.com
Tue Mar 16 21:47:03 UTC 2021
> Do any non-compiler-generated symbols include "."?
Yes, according to the output of nm:
$ i386-rtems6-nm build/i386/pc686/testsuites/libtests/block08.exe | grep " \."
0011bdd2 t .check_stack_switch
I don't think there are any function symbols that include ".", though.
> Are there symbols that start with a "." that might be caught? I know we do
> this in assembly programming often, e.g., ".vectors", although probably it is
> unlikely to appear in C/asm I just want to be thorough.
I didn't spot any when I looked:
$ grep -r "PUBLIC\s*(\." --exclude-dir=build
I guess it is possible, though. I'm not sure how I would properly handle it. Currently, covoar would just chop off everything after the ".", fail to find a coverage map, log an error, and move on.
Do we think that is good enough?
Alex
