Short commit message was Re: [rtems commit] rtems: Fix rtems_task_mode()
Joel Sherrill
joel at rtems.org
Thu Mar 18 13:15:11 UTC 2021
Sorry to pick Sebastian and I know it is too late to fix but in
providing feedback to Ryan and Alexon their commit messages,
"Fix XXX" was a pattern I realized really was not good and
encouraged them to avoid.
Look at https://git.rtems.org/rtems/log/ and see which ones give
you a solid hint and which ones say little beyond "I changed something".
I'm not sure how to turn this into solid guidance for the future
except that the title message should be short but specific enough
to hint at the purpose of the patch.
I think we all get in a hurry and forget that these messages are
permanent records and there for others (and ourselves) in the future.
No offense.
--joel
On Thu, Mar 18, 2021 at 4:39 AM Sebastian Huber <sebh at rtems.org> wrote:
> Module: rtems
> Branch: master
> Commit: 50abce31efeb54efd1957143e3cbf279785d8a9b
> Changeset:
> http://git.rtems.org/rtems/commit/?id=50abce31efeb54efd1957143e3cbf279785d8a9b
> Author: Sebastian Huber <sebastian.huber at embedded-brains.de>
> Date: Thu Mar 18 10:37:23 2021 +0100
> Do the ASR and preemption mode change only if requested by the mode
> mask. The bug was introduced by
> 508f868237225a75e566d9fd304206363cfe441d.
> cpukit/rtems/src/taskmode.c | 38 ++++++++++++++++++++++----------------
> 1 file changed, 22 insertions(+), 16 deletions(-)
> diff --git a/cpukit/rtems/src/taskmode.c b/cpukit/rtems/src/taskmode.c
> index 377224c..96bed47 100644
> --- a/cpukit/rtems/src/taskmode.c
> +++ b/cpukit/rtems/src/taskmode.c
> @@ -94,31 +94,37 @@ rtems_status_code rtems_task_mode(
> if ( ( mask & ( RTEMS_ASR_MASK | RTEMS_PREEMPT_MASK ) ) != 0 ) {
> bool need_thread_dispatch;
> ISR_lock_Context lock_context;
> - bool previous_asr_is_enabled;
> - bool previous_is_preemptible;
> need_thread_dispatch = false;
> _Thread_State_acquire( executing, &lock_context );
> - previous_asr_is_enabled = asr->is_enabled;
> - asr->is_enabled = !_Modes_Is_asr_disabled( mode_set );
> + if ( ( mask & RTEMS_ASR_MASK ) != 0 ) {
> + bool previous_asr_is_enabled;
> - if (
> - !previous_asr_is_enabled &&
> - asr->is_enabled &&
> - asr->signals_pending != 0
> - need_thread_dispatch = true;
> - _Thread_Append_post_switch_action( executing, &api->Signal_action );
> + previous_asr_is_enabled = asr->is_enabled;
> + asr->is_enabled = !_Modes_Is_asr_disabled( mode_set );
> + if (
> + !previous_asr_is_enabled &&
> + asr->is_enabled &&
> + asr->signals_pending != 0
> + need_thread_dispatch = true;
> + _Thread_Append_post_switch_action( executing, &api->Signal_action
> - previous_is_preemptible = executing->is_preemptible;
> - executing->is_preemptible = _Modes_Is_preempt( mode_set );
> + if ( ( mask & RTEMS_PREEMPT_MASK ) != 0 ) {
> + bool previous_is_preemptible;
> + previous_is_preemptible = executing->is_preemptible;
> + executing->is_preemptible = _Modes_Is_preempt( mode_set );
> - if ( executing->is_preemptible && !previous_is_preemptible ) {
> - _Scheduler_Schedule( executing );
> + if ( executing->is_preemptible && !previous_is_preemptible ) {
> + _Scheduler_Schedule( executing );
> if ( need_thread_dispatch ) {
> vc mailing list
> vc at rtems.org
> http://lists.rtems.org/mailman/listinfo/vc
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210318/b6528a5e/attachment.html>
