[PATCH v1 1/2] cpukit: Fixed 32bit pointers
Stephen Clark
stephen.clark at oarcorp.com
Thu Mar 18 14:17:50 UTC 2021
Using 32bit types like uint32_t for pointers creates issues on 64 bit
architectures like AArch64. Replaced occurrences of these with uintptr_t,
which will work for both 32 and 64 bit architectures.
cpukit/libdebugger/rtems-debugger-server.c | 4 ++--
cpukit/libdebugger/rtems-debugger-target.c | 2 +-
cpukit/libdebugger/rtems-debugger-target.h | 2 +-
cpukit/libmisc/rtems-fdt/rtems-fdt-shell.c | 4 ++--
cpukit/libmisc/stackchk/check.c | 3 ++-
5 files changed, 8 insertions(+), 7 deletions(-)
diff --git a/cpukit/libdebugger/rtems-debugger-server.c b/cpukit/libdebugger/rtems-debugger-server.c
index 975ec23a30..f8c485a794 100644
--- a/cpukit/libdebugger/rtems-debugger-server.c
+++ b/cpukit/libdebugger/rtems-debugger-server.c
@@ -1438,7 +1438,7 @@ remote_read_memory(uint8_t* buffer, int size)
if (comma == NULL)
remote_packet_out_str(r_E01);
else {
- DB_UINT addr;
+ uintptr_t addr;
DB_UINT length;
int r;
addr = hex_decode_uint(&buffer[1]);
@@ -1468,7 +1468,7 @@ remote_write_memory(uint8_t* buffer, int size)
comma = strchr((const char*) buffer, ',');
colon = strchr((const char*) buffer, ':');
if (comma != NULL && colon != NULL) {
- DB_UINT addr;
+ uintptr_t addr;
DB_UINT length;
int r;
diff --git a/cpukit/libdebugger/rtems-debugger-target.c b/cpukit/libdebugger/rtems-debugger-target.c
index bf7579700d..34e4e84d2f 100644
--- a/cpukit/libdebugger/rtems-debugger-target.c
+++ b/cpukit/libdebugger/rtems-debugger-target.c
@@ -168,7 +168,7 @@ rtems_debugger_target_reg_table_size(void)
int
-rtems_debugger_target_swbreak_control(bool insert, DB_UINT addr, DB_UINT kind)
+rtems_debugger_target_swbreak_control(bool insert, uintptr_t addr, DB_UINT kind)
rtems_debugger_target* target = rtems_debugger->target;
rtems_debugger_target_swbreak* swbreaks;
diff --git a/cpukit/libdebugger/rtems-debugger-target.h b/cpukit/libdebugger/rtems-debugger-target.h
index f2abbe5fd3..db356e1f07 100644
--- a/cpukit/libdebugger/rtems-debugger-target.h
+++ b/cpukit/libdebugger/rtems-debugger-target.h
@@ -200,7 +200,7 @@ extern void rtems_debugger_target_exception_print(CPU_Exception_frame* frame);
* Software breakpoints. These are also referred to as memory breakpoints.
extern int rtems_debugger_target_swbreak_control(bool insert,
- DB_UINT addr,
+ uintptr_t addr,
DB_UINT kind);
diff --git a/cpukit/libmisc/rtems-fdt/rtems-fdt-shell.c b/cpukit/libmisc/rtems-fdt/rtems-fdt-shell.c
index b0894c1d38..61f20765e0 100644
--- a/cpukit/libmisc/rtems-fdt/rtems-fdt-shell.c
+++ b/cpukit/libmisc/rtems-fdt/rtems-fdt-shell.c
@@ -52,14 +52,14 @@ static long rtems_fdt_test_timeout = 5;
static rtems_fdt_handle cmd_fdt_handle;
static void
-rtems_fdt_write (uint32_t address, uint32_t value)
+rtems_fdt_write (uintptr_t address, uint32_t value)
volatile uint32_t* ap = (uint32_t*) address;
*ap = value;
static uint32_t
-rtems_fdt_read (uint32_t address)
+rtems_fdt_read (uintptr_t address)
return *ap;
diff --git a/cpukit/libmisc/stackchk/check.c b/cpukit/libmisc/stackchk/check.c
index ab08155c92..a2b63345d9 100644
--- a/cpukit/libmisc/stackchk/check.c
+++ b/cpukit/libmisc/stackchk/check.c
@@ -447,12 +447,13 @@ static bool Stack_check_Dump_threads_usage(
char name[ 22 ];
const rtems_printer *printer;
+ uintptr_t sp = _CPU_Context_Get_SP( &the_thread->Registers );
printer = arg;
_Thread_Get_name( the_thread, name, sizeof( name ) );
Stack_check_Dump_stack_usage(
&the_thread->Start.Initial_stack,
- (void *) _CPU_Context_Get_SP( &the_thread->Registers ),
+ (void *) sp,
name,
the_thread->Object.id,
printer
2.27.0
