[PATCH v2 1/3] rtems-debugger: Fixed 32bit pointers
Stephen Clark stephen.clark at oarcorp.com
Thu Mar 18 17:33:08 UTC 2021
Using 32bit types like uint32_t for pointers creates issues on 64 bit
architectures like AArch64. Replaced occurrences of these with uintptr_t,
which will work for both 32 and 64 bit architectures.
 cpukit/libdebugger/rtems-debugger-server.c | 4 ++--
 cpukit/libdebugger/rtems-debugger-target.c | 2 +-
 cpukit/libdebugger/rtems-debugger-target.h | 2 +-
 3 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/cpukit/libdebugger/rtems-debugger-server.c b/cpukit/libdebugger/rtems-debugger-server.c
index 975ec23a30..f8c485a794 100644
--- a/cpukit/libdebugger/rtems-debugger-server.c
+++ b/cpukit/libdebugger/rtems-debugger-server.c
@@ -1438,7 +1438,7 @@ remote_read_memory(uint8_t* buffer, int size)
   if (comma == NULL)
     remote_packet_out_str(r_E01);
   else {
-    DB_UINT addr;
+    uintptr_t addr;
     DB_UINT length;
     int     r;
     addr = hex_decode_uint(&buffer[1]);
@@ -1468,7 +1468,7 @@ remote_write_memory(uint8_t* buffer, int size)
   comma = strchr((const char*) buffer, ',');
   colon = strchr((const char*) buffer, ':');
   if (comma != NULL && colon != NULL) {
-    DB_UINT addr;
+    uintptr_t addr;
     DB_UINT length;
     int     r;
diff --git a/cpukit/libdebugger/rtems-debugger-target.c b/cpukit/libdebugger/rtems-debugger-target.c
index bf7579700d..34e4e84d2f 100644
--- a/cpukit/libdebugger/rtems-debugger-target.c
+++ b/cpukit/libdebugger/rtems-debugger-target.c
@@ -168,7 +168,7 @@ rtems_debugger_target_reg_table_size(void)
 int
-rtems_debugger_target_swbreak_control(bool insert, DB_UINT addr, DB_UINT kind)
+rtems_debugger_target_swbreak_control(bool insert, uintptr_t addr, DB_UINT kind)
   rtems_debugger_target*         target = rtems_debugger->target;
   rtems_debugger_target_swbreak* swbreaks;
diff --git a/cpukit/libdebugger/rtems-debugger-target.h b/cpukit/libdebugger/rtems-debugger-target.h
index f2abbe5fd3..db356e1f07 100644
--- a/cpukit/libdebugger/rtems-debugger-target.h
+++ b/cpukit/libdebugger/rtems-debugger-target.h
@@ -200,7 +200,7 @@ extern void rtems_debugger_target_exception_print(CPU_Exception_frame* frame);
  * Software breakpoints. These are also referred to as memory breakpoints.
 extern int rtems_debugger_target_swbreak_control(bool    insert,
-                                                 DB_UINT addr,
+                                                 uintptr_t addr,
                                                  DB_UINT kind);
2.27.0
