[PATCH v2 1/3] rtems-debugger: Fixed 32bit pointers
Joel Sherrill
joel at rtems.org
Thu Mar 18 18:13:44 UTC 2021
On Thu, Mar 18, 2021, 1:10 PM Stephen Clark <stephen.clark at oarcorp.com>
wrote:
> I think Sebastian and Gedare might have referenced this earlier, but I’m
> not sure if how to be that descriptive within the 50 character limit. "Use
> uintptr_t not uint32_t for portability to 64-bit CPUs" is 58 characters
> without a prefix. Even when pared down to something like “Use uintptr_t to
> build on 64-bit CPUs”, there still isn’t room to prepend “rtems-debugger:”.
I don't think these HAVE to be less than 80 columns just close. But you
could drop "not uint32_t" and "for portability" if needed
> *From:* Joel Sherrill <joel at rtems.org>
> *Sent:* Thursday, March 18, 2021 12:50 PM
> *To:* Stephen Clark <stephen.clark at oarcorp.com>
> *Cc:* rtems-devel at rtems.org <devel at rtems.org>
> *Subject:* Re: [PATCH v2 1/3] rtems-debugger: Fixed 32bit pointers
> After picking on Ryan, Alex, and Sebastian, you get it next. :)
> "Fix" or "Fixed" in the short commit message title is not useful
> when you browse the log of commits:
> https://git.rtems.org/rtems/log/
> Something like "Use uint32_t not uintptr_t for portability to 64-bit CPUs"
> says a lot more. Think of yourself reading that list of commits and what
> messages tell you enough and which leave you thinking that you need
> to look at the change to know what was done.
> On Thu, Mar 18, 2021 at 12:33 PM Stephen Clark <stephen.clark at oarcorp.com>
> wrote:
> Using 32bit types like uint32_t for pointers creates issues on 64 bit
> architectures like AArch64. Replaced occurrences of these with uintptr_t,
> which will work for both 32 and 64 bit architectures.
> cpukit/libdebugger/rtems-debugger-server.c | 4 ++--
> cpukit/libdebugger/rtems-debugger-target.c | 2 +-
> cpukit/libdebugger/rtems-debugger-target.h | 2 +-
> 3 files changed, 4 insertions(+), 4 deletions(-)
> diff --git a/cpukit/libdebugger/rtems-debugger-server.c
> b/cpukit/libdebugger/rtems-debugger-server.c
> index 975ec23a30..f8c485a794 100644
> --- a/cpukit/libdebugger/rtems-debugger-server.c
> +++ b/cpukit/libdebugger/rtems-debugger-server.c
> @@ -1438,7 +1438,7 @@ remote_read_memory(uint8_t* buffer, int size)
> if (comma == NULL)
> remote_packet_out_str(r_E01);
> else {
> - DB_UINT addr;
> + uintptr_t addr;
> DB_UINT length;
> int r;
> addr = hex_decode_uint(&buffer[1]);
> @@ -1468,7 +1468,7 @@ remote_write_memory(uint8_t* buffer, int size)
> comma = strchr((const char*) buffer, ',');
> colon = strchr((const char*) buffer, ':');
> if (comma != NULL && colon != NULL) {
> - DB_UINT addr;
> + uintptr_t addr;
> DB_UINT length;
> int r;
> I think the changes OK but Chris should comment what
> happens on 64-bit address targets.
> I think this may be decoding the gdb protocol message and we need
> to know if the field coming in is OK to decode as a uint.
> Your patch is OK but there may be an issue interfacing with the protocol
> that this points out.
> diff --git a/cpukit/libdebugger/rtems-debugger-target.c
> b/cpukit/libdebugger/rtems-debugger-target.c
> index bf7579700d..34e4e84d2f 100644
> --- a/cpukit/libdebugger/rtems-debugger-target.c
> +++ b/cpukit/libdebugger/rtems-debugger-target.c
> @@ -168,7 +168,7 @@ rtems_debugger_target_reg_table_size(void)
> int
> -rtems_debugger_target_swbreak_control(bool insert, DB_UINT addr, DB_UINT
> kind)
> +rtems_debugger_target_swbreak_control(bool insert, uintptr_t addr,
> DB_UINT kind)
> rtems_debugger_target* target = rtems_debugger->target;
> rtems_debugger_target_swbreak* swbreaks;
> diff --git a/cpukit/libdebugger/rtems-debugger-target.h
> b/cpukit/libdebugger/rtems-debugger-target.h
> index f2abbe5fd3..db356e1f07 100644
> --- a/cpukit/libdebugger/rtems-debugger-target.h
> +++ b/cpukit/libdebugger/rtems-debugger-target.h
> @@ -200,7 +200,7 @@ extern void
> rtems_debugger_target_exception_print(CPU_Exception_frame* frame);
> * Software breakpoints. These are also referred to as memory breakpoints.
> extern int rtems_debugger_target_swbreak_control(bool insert,
> - DB_UINT addr,
> + uintptr_t addr,
> DB_UINT kind);
> 2.27.0
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210318/0a5e296f/attachment.html>
