[PATCH v2] pwdgrp.c: removed assert causing runtime issues
Thu Mar 18 19:19:14 UTC 2021
On Thu, Mar 18, 2021 at 2:14 PM Gedare Bloom <gedare at rtems.org> wrote:
> On Thu, Mar 18, 2021 at 11:40 AM Ryan Long <ryan.long at oarcorp.com> wrote:
> > Changed the _Assert_unused_variable_equals macro to just a (void) due to
> > /etc having already been created by the network stack initialization
> > or an initial filesystem image.
> > Updates #4282
> >  cpukit/libcsupport/src/pwdgrp.c | 9 ++++-----
> >  1 file changed, 4 insertions(+), 5 deletions(-)
> > diff --git a/cpukit/libcsupport/src/pwdgrp.c
> b/cpukit/libcsupport/src/pwdgrp.c
> > index f4a10f7..edc8aff 100644
> > --- a/cpukit/libcsupport/src/pwdgrp.c
> > +++ b/cpukit/libcsupport/src/pwdgrp.c
> > @@ -36,7 +36,6 @@
> >  #include <stdint.h>
> >  #include <rtems/seterr.h>
> > -#include <rtems/score/assert.h>
> >  #include "pwdgrp.h"
> > @@ -63,13 +62,13 @@ static void init_file(const char *name, const char
> *content)
> >  static void pwdgrp_init(void)
> > -  int sc;
> >     * Do the best to create this directory.
> > +   * /etc could be created by the network stack initialization or an
> initial
> > +   * filesystem image. Deliberately ignore the return value.
> > -  sc = mkdir("/etc", S_IRWXU | S_IRGRP | S_IXGRP | S_IROTH | S_IXOTH);
> > -  _Assert_Unused_variable_equals(sc, 0);
> > +  (void) mkdir("/etc", S_IRWXU | S_IRGRP | S_IXGRP | S_IROTH | S_IXOTH);
> So this seems fine, but it got me thinking, does this issue affect all
> the other mkdir-related patches recently done?
> Probably, we should use
> _Assert(sc == 0 || errno == EEXIST);
> (void) sc;
If we are sure that it is OK for it to exist and that's the errno returned.
But if it isn't, that's probably another bug.
FWIW this seems typical of static analysis issues to me. FIx it wrong, then
fix it again a correct way, and then realize there was an even better way to
fix it. I presented a case at the Flight Software Workshop where I think I
went
through multiple solutions before realizing B0 was special in POSIX to hang
up a line and the UART device driver had to say "not supported" instead of
an assert to avoid a divide by zero.
These are often more subtle than they appear on first examination.
> >     *  Initialize /etc/passwd
> > 1.8.3.1
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210318/4c8bf25c/attachment.html>
