[PATCH v2] pwdgrp.c: removed assert causing runtime issues
Joel Sherrill joel.sherrill at gmail.com
Thu Mar 18 19:20:04 UTC 2021
On Thu, Mar 18, 2021 at 2:16 PM Ryan Long <ryan.long at oarcorp.com> wrote:
> When Joel and I looked at it, this was the only assert that prevented it
> from running.
But Gedare's suggestion is good since it is a VERY precise check.
--joel
> -----Original Message-----
> From: Gedare Bloom <gedare at rtems.org>
> Sent: Thursday, March 18, 2021 2:14 PM
> To: Ryan Long <ryan.long at oarcorp.com>
> Cc: devel at rtems.org
> Subject: Re: [PATCH v2] pwdgrp.c: removed assert causing runtime issues
> On Thu, Mar 18, 2021 at 11:40 AM Ryan Long <ryan.long at oarcorp.com> wrote:
> > Changed the _Assert_unused_variable_equals macro to just a (void) due
> > to /etc having already been created by the network stack
> > initialization or an initial filesystem image.
> > Updates #4282
> >  cpukit/libcsupport/src/pwdgrp.c | 9 ++++-----
> >  1 file changed, 4 insertions(+), 5 deletions(-)
> > diff --git a/cpukit/libcsupport/src/pwdgrp.c
> > b/cpukit/libcsupport/src/pwdgrp.c index f4a10f7..edc8aff 100644
> > --- a/cpukit/libcsupport/src/pwdgrp.c
> > +++ b/cpukit/libcsupport/src/pwdgrp.c
> > @@ -36,7 +36,6 @@
> >  #include <stdint.h>
> >  #include <rtems/seterr.h>
> > -#include <rtems/score/assert.h>
> >  #include "pwdgrp.h"
> > @@ -63,13 +62,13 @@ static void init_file(const char *name, const char
> *content)
> >  static void pwdgrp_init(void)
> > -  int sc;
> >     * Do the best to create this directory.
> > +   * /etc could be created by the network stack initialization or an
> initial
> > +   * filesystem image. Deliberately ignore the return value.
> > -  sc = mkdir("/etc", S_IRWXU | S_IRGRP | S_IXGRP | S_IROTH |
> > S_IXOTH);
> > -  _Assert_Unused_variable_equals(sc, 0);
> > +  (void) mkdir("/etc", S_IRWXU | S_IRGRP | S_IXGRP | S_IROTH |
> > + S_IXOTH);
> So this seems fine, but it got me thinking, does this issue affect all the
> other mkdir-related patches recently done?
> Probably, we should use
> _Assert(sc == 0 || errno == EEXIST);
> (void) sc;
> >     *  Initialize /etc/passwd
> > 1.8.3.1
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210318/26970c88/attachment.html>
