[PATCH 3/3] bsps/aarch64: changed comments and test statuses
Ryan Long ryan.long at oarcorp.com
Thu Mar 18 20:27:08 UTC 2021
Expanded upon the commments that were present previously.
Added more tests that may finish as 'indeterminate'.
 spec/build/bsps/aarch64/a53/tsta53.yml            | 39 +++++++++++++++++++----
 spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml | 39 +++++++++++++++++++----
 2 files changed, 66 insertions(+), 12 deletions(-)
diff --git a/spec/build/bsps/aarch64/a53/tsta53.yml b/spec/build/bsps/aarch64/a53/tsta53.yml
index 6876d23..5b60f52 100644
--- a/spec/build/bsps/aarch64/a53/tsta53.yml
+++ b/spec/build/bsps/aarch64/a53/tsta53.yml
@@ -1,20 +1,25 @@
 SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
 actions:
 - set-test-state:
-    # expected to fail, don't compile these
+    # This test fails when ran through rtems-tester because it does not
+    # produce any output.
     minimum: exclude
-    # don't compile due to toolchain issues
+    # These tests do not compile due to an issue with the GNU Assembler.
+    # The issue has been filed(https://devel.rtems.org/ticket/4218).
+    # Once the issue has been fixed, these tests will be turned back on.
     spconfig01: exclude
     spmisc01: exclude
-    # tests that are passing intermittently
+    # These tests may or may not fail, however, they do pass on real hardware.
+    # It seems to be an issue with Qemu. and that this only occurs when the
     spcpucounter01: indeterminate
     rtmonuse: indeterminate
-    sp68: indeterminate
     sp04: indeterminate
     sp20: indeterminate
+    sp68: indeterminate
     sp69: indeterminate
+    sp71: indeterminate
     rtmonusxtimes01: indeterminate
     spedfsched02: indeterminate
     spedfsched04: indeterminate
@@ -24,12 +29,34 @@ actions:
     sptimecounter04: indeterminate
     ttest02: indeterminate
-    # tests that pass nominally, but fail under Qemu when the host is under
-    # heavy load
+    # It seems to be an issue with Qemu, and that this only occurs when the
+    # host machine is under a heavy load.
     psx12: indeterminate
+    spintrcritical01: indeterminate
+    spintrcritical02: indeterminate
     spintrcritical03: indeterminate
     spintrcritical04: indeterminate
     spintrcritical05: indeterminate
+    spintrcritical06: indeterminate
+    spintrcritical07: indeterminate
+    spintrcritical08: indeterminate
+    spintrcritical09: indeterminate
+    spintrcritical10: indeterminate
+    spintrcritical11: indeterminate
+    spintrcritical12: indeterminate
+    spintrcritical13: indeterminate
+    spintrcritical14: indeterminate
+    spintrcritical15: indeterminate
+    spintrcritical16: indeterminate
+    spintrcritical17: indeterminate
+    spintrcritical18: indeterminate
+    spintrcritical19: indeterminate
+    spintrcritical20: indeterminate
+    spintrcritical21: indeterminate
+    spintrcritical22: indeterminate
+    spintrcritical23: indeterminate
+    spintrcritical24: indeterminate
 build-type: option
 copyrights:
 - Copyright (C) 2020 On-Line Applications Research (OAR)
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml
index 80d338f..1862815 100644
--- a/spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml
@@ -1,20 +1,25 @@
 actions:
 - set-test-state:
     minimum: exclude
     spconfig01: exclude
     spmisc01: exclude
     sp04: indeterminate
     sp20: indeterminate
     sp69: indeterminate
-    # heavy load
 build-type: option
 copyrights:
1.8.3.1
