Ada Tests Not Linking
Joel Sherrill
joel at rtems.org
Thu Mar 18 22:44:54 UTC 2021
Hi
I am trying to build Ada tests for the leon3 and all fail to link. When did
these build last?
I need to look at adaint.c to see if there is an alternative implementation
choice. But, if there isn't, does anyone see an option other than porting
at least a minimal version of the missing method(s) what should I do?
sparc-rtems6-gnatlink
/home/joel/test-gcc/rtems/b-leon3/sparc/leon3/testsuites/ada/sptests/sp09/sp09.ali
testsuites/ada/sptests/sp09/init.o -qnolinkcmds -T linkcmds.leon3
-Wl,--wrap=printf -Wl,--wrap=puts -L. -lrtemscpu -lrtemsbsp -lrtemstest
-qrtems -mcpu=leon3 -Wl,--gc-sections
-L/home/joel/test-gcc/rtems/bsps/sparc/shared/start
-L/home/joel/test-gcc/rtems/bsps/sparc/leon3/start -o
/home/joel/test-gcc/rtems/b-leon3/sparc/leon3/testsuites/ada/ada_sp09.exe
/home/joel/test-gcc/install-master/lib/gcc/sparc-rtems6/11.0.1/../../../../sparc-rtems6/bin/ld:
/home/joel/test-gcc/install-master/lib/gcc/sparc-rtems6/11.0.1/leon3/adalib/libgnat.a(adaint.o):
in function `__gnat_copy_attribs':
/home/joel/test-gcc/b-sparc-rtems6-gcc/gcc/ada/rts_leon3/adaint.c:3295:
undefined reference to `utimensat'
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210318/caafcda1/attachment-0001.html>
