[PATCH] gsoc_task: Proof that I can contribute to RTEMS in GSoC
Rajiv Vaidyanathan
rajiv.vaidyanathan4 at gmail.com
Sat Mar 20 05:34:53 UTC 2021
Hi Gedare,
Thank you for providing feedback on the patch. I'll make sure I follow the
character limit guidelines from now on. I have added my info template to
the Students' Proposals table.
I looked into the open projects and found the following projects
interesting:
1. https://devel.rtems.org/ticket/3855
2. https://devel.rtems.org/ticket/3892
It would be great if you can provide some guidance regarding these tickets.
I just realised that I never introduced myself 😅 I am Rajiv Vaidyanathan
studying Masters in Computer Science at IIT Bombay, India. In my coursework
and projects/ labs, I have gained some experience in systems programming
and real time operating systems. I am extremely excited to contribute to
RTEMS.
Thanks and regards,
Rajiv
On Fri, 19 Mar 2021 at 20:21, Gedare Bloom <gedare at rtems.org> wrote:
> Hi Rajiv,
> On Fri, Mar 19, 2021 at 4:21 AM Rajiv Vaidyanathan
> <rajiv.vaidyanathan4 at gmail.com> wrote:
> > Link to the task:
> https://docs.rtems.org/branches/master/user/start/gsoc.html
> > testsuites/samples/hello/init.c | 2 +-
> > 1 file changed, 1 insertion(+), 1 deletion(-)
> > diff --git a/testsuites/samples/hello/init.c
> b/testsuites/samples/hello/init.c
> > index 34ded37c55..a4e556de19 100644
> > --- a/testsuites/samples/hello/init.c
> > +++ b/testsuites/samples/hello/init.c
> > @@ -22,7 +22,7 @@ static rtems_task Init(
> > rtems_print_printer_fprintf_putc(&rtems_test_printer);
> > TEST_BEGIN();
> > - printf( "Hello World\n" );
> > + printf( "Hello from The Dark Side! I'm Rajiv Vaidyanathan and am
> excited to contribute to RTEMS at GSoC2021!\n" );
> This is fine for the proof. Note that we limit code line lengths to 80
> characters in practice:
> https://docs.rtems.org/branches/master/eng/coding-formatting.html#eighty-character-line-limit
> Please add your info to
> https://devel.rtems.org/wiki/GSoC/2021#StudentsProposals
> and start to investigate which open projects you might like to
> consider. You will need to engage on the devel mailing list with the
> potential mentors about those projects, as some of the projects may be
> no longer available or suitable, and in general the projects need to
> be scoped appropriately. This engagement is best done in a separate
> email thread dedicated to the proposed area(s) you want to investigate.
> > TEST_END();
> > rtems_test_exit( 0 );
> > 2.25.1
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210320/ed3e1636/attachment.html>
