[PATCH] gsoc_task: Proof that I can contribute to RTEMS in GSoC
Rajiv Vaidyanathan rajiv.vaidyanathan4 at gmail.com
Sat Mar 20 06:17:01 UTC 2021
Hi Gedare,
Thanks for the feedback. I'll avoid adding links here and just mention the
ticket numbers. Regarding the systems related tickets, I looked into #2904
(memory protection) and #2899 (Improving the RPi BSP). It would be great if
you can provide some information regarding the status of these projects. I
saw that #2904 was addressed in previous GSoC editions and #2899 seems to
be inactive since 2017. If any of these is open this year, I am very
excited to pursue them.
Thanks and regards,
Rajiv
On Sat, 20 Mar 2021 at 11:34, Gedare Bloom <gedare at rtems.org> wrote:
> Hi Rajiv,
> On Fri, Mar 19, 2021 at 11:35 PM Rajiv Vaidyanathan <
> rajiv.vaidyanathan4 at gmail.com> wrote:
>> Hi Gedare,
>> Thank you for providing feedback on the patch. I'll make sure I follow
>> the character limit guidelines from now on. I have added my info template
>> to the Students' Proposals table.
>> I looked into the open projects and found the following projects
>> interesting:
>> 1. https://devel.rtems.org/ticket/3855
>> 2. https://devel.rtems.org/ticket/3892
>> It would be great if you can provide some guidance regarding these
>> tickets.
>> You may like to start threads about each of those possible projects with
> clear email subject lines, so that you may get the attention of the
> potential mentors. Not all mentors will be reading every email
> continuously, and also we don't all know the ticket numbers or click on
> links in emails.
> That said, I know the EPICS BSP Buildset project had some work done last
> summer, and I think it is almost finished now with some recent effort that
> has been done in the past month, so I don't think there is enough in that
> specific direction for a GSoC scope anymore.
>> I just realised that I never introduced myself 😅 I am Rajiv Vaidyanathan
>> studying Masters in Computer Science at IIT Bombay, India. In my coursework
>> and projects/ labs, I have gained some experience in systems programming
>> and real time operating systems. I am extremely excited to contribute to
>> RTEMS.
>> Great. If you have systems programming experience, I would encourage you
> to not be afraid to take on some projects that push you into the C
> programming. I saw the two you picked are more Python oriented, but maybe
> you will have more fun hacking in the kernel? Just a thought.
>> Thanks and regards,
>> Rajiv
>> On Fri, 19 Mar 2021 at 20:21, Gedare Bloom <gedare at rtems.org> wrote:
>>> Hi Rajiv,
>>> On Fri, Mar 19, 2021 at 4:21 AM Rajiv Vaidyanathan
>>> <rajiv.vaidyanathan4 at gmail.com> wrote:
>>> > Link to the task:
>>> https://docs.rtems.org/branches/master/user/start/gsoc.html
>>> >  testsuites/samples/hello/init.c | 2 +-
>>> >  1 file changed, 1 insertion(+), 1 deletion(-)
>>> > diff --git a/testsuites/samples/hello/init.c
>>> b/testsuites/samples/hello/init.c
>>> > index 34ded37c55..a4e556de19 100644
>>> > --- a/testsuites/samples/hello/init.c
>>> > +++ b/testsuites/samples/hello/init.c
>>> > @@ -22,7 +22,7 @@ static rtems_task Init(
>>> >    rtems_print_printer_fprintf_putc(&rtems_test_printer);
>>> >    TEST_BEGIN();
>>> > -  printf( "Hello World\n" );
>>> > +  printf( "Hello from The Dark Side! I'm Rajiv Vaidyanathan and am
>>> excited to contribute to RTEMS at GSoC2021!\n" );
>>> This is fine for the proof. Note that we limit code line lengths to 80
>>> characters in practice:
>>> https://docs.rtems.org/branches/master/eng/coding-formatting.html#eighty-character-line-limit
>>> Please add your info to
>>> https://devel.rtems.org/wiki/GSoC/2021#StudentsProposals
>>> and start to investigate which open projects you might like to
>>> consider. You will need to engage on the devel mailing list with the
>>> potential mentors about those projects, as some of the projects may be
>>> no longer available or suitable, and in general the projects need to
>>> be scoped appropriately. This engagement is best done in a separate
>>> email thread dedicated to the proposed area(s) you want to investigate.
>>> >    TEST_END();
>>> >    rtems_test_exit( 0 );
>>> > 2.25.1
>>> > _______________________________________________
>>> > devel mailing list
>>> > devel at rtems.org
>>> > http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210320/bba58ecd/attachment.html>
