[PATCH v3 1/3] rtems-debugger: Fixed 32bit pointers
Gedare Bloom
gedare at rtems.org
Sat Mar 20 06:21:21 UTC 2021
Hi Stephen, Joel:
On Fri, Mar 19, 2021 at 9:35 AM Stephen Clark <stephen.clark at oarcorp.com> wrote:
> Using 32bit types like uint32_t for pointers creates issues on 64 bit
> architectures like AArch64. Replaced occurrences of these with uintptr_t,
> which will work for both 32 and 64 bit architectures.
> cpukit/libdebugger/rtems-debugger-server.c | 4 ++--
> cpukit/libdebugger/rtems-debugger-target.c | 2 +-
> cpukit/libdebugger/rtems-debugger-target.h | 2 +-
> 3 files changed, 4 insertions(+), 4 deletions(-)
> diff --git a/cpukit/libdebugger/rtems-debugger-server.c b/cpukit/libdebugger/rtems-debugger-server.c
> index 975ec23a30..f8c485a794 100644
> --- a/cpukit/libdebugger/rtems-debugger-server.c
> +++ b/cpukit/libdebugger/rtems-debugger-server.c
> @@ -1438,7 +1438,7 @@ remote_read_memory(uint8_t* buffer, int size)
> if (comma == NULL)
> remote_packet_out_str(r_E01);
> else {
> - DB_UINT addr;
> + uintptr_t addr;
> DB_UINT length;
> int r;
> addr = hex_decode_uint(&buffer[1]);
I still have concerns that just changing the variable types is not
addressing any possible fundamental type errors that get hidden by
later type coercion, for example, here we see addr = hex_decode_uint()
that returns type DB_UINT, so now we have a type mismatch in 64-bit
targets. Now, maybe it is fine, because the addresses are limited to
32-bits in practice, but I would like some discussion of the analysis
that has been done on these type changes.
> @@ -1468,7 +1468,7 @@ remote_write_memory(uint8_t* buffer, int size)
> comma = strchr((const char*) buffer, ',');
> colon = strchr((const char*) buffer, ':');
> if (comma != NULL && colon != NULL) {
> - DB_UINT addr;
> + uintptr_t addr;
> DB_UINT length;
> int r;
> diff --git a/cpukit/libdebugger/rtems-debugger-target.c b/cpukit/libdebugger/rtems-debugger-target.c
> index bf7579700d..34e4e84d2f 100644
> --- a/cpukit/libdebugger/rtems-debugger-target.c
> +++ b/cpukit/libdebugger/rtems-debugger-target.c
> @@ -168,7 +168,7 @@ rtems_debugger_target_reg_table_size(void)
> int
> -rtems_debugger_target_swbreak_control(bool insert, DB_UINT addr, DB_UINT kind)
> +rtems_debugger_target_swbreak_control(bool insert, uintptr_t addr, DB_UINT kind)
> rtems_debugger_target* target = rtems_debugger->target;
> rtems_debugger_target_swbreak* swbreaks;
> diff --git a/cpukit/libdebugger/rtems-debugger-target.h b/cpukit/libdebugger/rtems-debugger-target.h
> index f2abbe5fd3..db356e1f07 100644
> --- a/cpukit/libdebugger/rtems-debugger-target.h
> +++ b/cpukit/libdebugger/rtems-debugger-target.h
> @@ -200,7 +200,7 @@ extern void rtems_debugger_target_exception_print(CPU_Exception_frame* frame);
> * Software breakpoints. These are also referred to as memory breakpoints.
> extern int rtems_debugger_target_swbreak_control(bool insert,
> - DB_UINT addr,
> + uintptr_t addr,
> DB_UINT kind);
> 2.27.0
> devel mailing list
> devel at rtems.org
