[PATCH rtems v2 1/2] libblock: Add rtems_bdbuf_peek()
Christian MAUDERER
christian.mauderer at embedded-brains.de
Mon Mar 22 15:32:43 UTC 2021
Am 22.03.21 um 15:55 schrieb Gedare Bloom:
> On Mon, Mar 22, 2021 at 2:27 AM Christian Mauderer
> <christian.mauderer at embedded-brains.de> wrote:
>> Adds a peek function that allows (for example) a file system to suggest
>> the next blocks that should be used for read ahead. This can increase
>> the read speed of fragmented files.
>> cpukit/include/rtems/bdbuf.h | 21 ++++
>> cpukit/include/rtems/diskdevs.h | 24 ++++-
>> cpukit/libblock/src/bdbuf.c | 84 +++++++++++----
>> cpukit/libblock/src/blkdev-print-stats.c | 2 +
>> testsuites/fstests/fsdosfswrite01/init.c | 3 +
>> testsuites/libtests/block14/block14.scn | 19 +++-
>> testsuites/libtests/block14/init.c | 124 +++++++++++++++++------
>> 7 files changed, 217 insertions(+), 60 deletions(-)
>> diff --git a/cpukit/include/rtems/bdbuf.h b/cpukit/include/rtems/bdbuf.h
>> index fbb4fc05e9..0cde571816 100644
>> --- a/cpukit/include/rtems/bdbuf.h
>> +++ b/cpukit/include/rtems/bdbuf.h
>> @@ -539,6 +539,27 @@ rtems_bdbuf_read (
>> rtems_bdbuf_buffer** bd
> missing @brief?
> rest of this looks fine on a quick skim
Didn't seem to be the style of the other comments in that header. So I
didn't add one here either. Would the following one be OK:
@brief: Give a hint which blocks should be cached next.
>> + * Provide a hint to the read ahead mechanism which blocks should be cached
>> + * next. This overwrites the default linear pattern. You should use it in (for
>> + * example) a file system to tell bdbuf where the next part of a fragmented file
>> + * is. If you know the length of the file, you can provide that too.
>> + * Before you can use this function, the rtems_bdbuf_init() routine must be
>> + * called at least once to initialize everything. Otherwise you might get
>> + * unexpected results.
>> + * @param dd [in] The disk device.
>> + * @param block [in] Linear media block number.
>> + * @param nr_blocks [in] Number of consecutive blocks that can be pre-fetched.
>> +void
>> +rtems_bdbuf_peek (
>> + rtems_disk_device *dd,
>> + rtems_blkdev_bnum block,
>> + uint32_t nr_blocks
>> * Release the buffer obtained by a read call back to the cache. If the buffer
>> * was obtained by a get call and was not already in the cache the release
>> diff --git a/cpukit/include/rtems/diskdevs.h b/cpukit/include/rtems/diskdevs.h
>> index 85d157dcd5..527a8cc955 100644
>> --- a/cpukit/include/rtems/diskdevs.h
>> +++ b/cpukit/include/rtems/diskdevs.h
>> @@ -58,6 +58,11 @@ typedef int (*rtems_block_device_ioctl)(
>> #define RTEMS_DISK_READ_AHEAD_NO_TRIGGER ((rtems_blkdev_bnum) -1)
>> + * @brief Size value to set number of blocks based on config and disk size.
>> +#define RTEMS_DISK_READ_AHEAD_SIZE_AUTO (0)
>> * @brief Block device read-ahead control.
>> @@ -71,7 +76,8 @@ typedef struct {
>> * @brief Block value to trigger the read-ahead request.
>> * A value of @ref RTEMS_DISK_READ_AHEAD_NO_TRIGGER will disable further
>> - * read-ahead requests since no valid block can have this value.
>> + * read-ahead requests (except the ones triggered by @a rtems_bdbuf_peek)
>> + * since no valid block can have this value.
>> rtems_blkdev_bnum trigger;
>> @@ -82,6 +88,14 @@ typedef struct {
>> * be arbitrary.
>> rtems_blkdev_bnum next;
>> + * @brief Size of the next read-ahead request in blocks.
>> + * A value of @ref RTEMS_DISK_READ_AHEAD_SIZE_AUTO will try to read the rest
>> + * of the disk but at most the configured max_read_ahead_blocks.
>> + uint32_t nr_blocks;
>> } rtems_blkdev_read_ahead;
>> @@ -110,10 +124,16 @@ typedef struct {
>> * @brief Read-ahead transfer count.
>> - * Each read-ahead transfer may read multiple blocks.
>> + * Each read-ahead transfer may read multiple blocks. This counts all
>> + * transfers (including peeks).
>> uint32_t read_ahead_transfers;
>> + * @brief Read-ahead transfers caused by a peek.
>> + uint32_t read_ahead_peeks;
>> * @brief Count of blocks transfered from the device.
>> diff --git a/cpukit/libblock/src/bdbuf.c b/cpukit/libblock/src/bdbuf.c
>> index a7d471507c..8aadf9c8ae 100644
>> --- a/cpukit/libblock/src/bdbuf.c
>> +++ b/cpukit/libblock/src/bdbuf.c
>> @@ -2018,6 +2018,23 @@ rtems_bdbuf_read_ahead_reset (rtems_disk_device *dd)
>> dd->read_ahead.trigger = RTEMS_DISK_READ_AHEAD_NO_TRIGGER;
>> +static void
>> +rtems_bdbuf_read_ahead_add_to_chain (rtems_disk_device *dd)
>> + rtems_status_code sc;
>> + rtems_chain_control *chain = &bdbuf_cache.read_ahead_chain;
>> + if (rtems_chain_is_empty (chain))
>> + sc = rtems_event_send (bdbuf_cache.read_ahead_task,
>> + RTEMS_BDBUF_READ_AHEAD_WAKE_UP);
>> + if (sc != RTEMS_SUCCESSFUL)
>> + rtems_bdbuf_fatal (RTEMS_BDBUF_FATAL_RA_WAKE_UP);
>> + rtems_chain_append_unprotected (chain, &dd->read_ahead.node);
>> static void
>> rtems_bdbuf_check_read_ahead_trigger (rtems_disk_device *dd,
>> rtems_blkdev_bnum block)
>> @@ -2026,18 +2043,8 @@ rtems_bdbuf_check_read_ahead_trigger (rtems_disk_device *dd,
>> && dd->read_ahead.trigger == block
>> && !rtems_bdbuf_is_read_ahead_active (dd))
>> - rtems_status_code sc;
>> - rtems_chain_control *chain = &bdbuf_cache.read_ahead_chain;
>> - if (rtems_chain_is_empty (chain))
>> - sc = rtems_event_send (bdbuf_cache.read_ahead_task,
>> - RTEMS_BDBUF_READ_AHEAD_WAKE_UP);
>> - if (sc != RTEMS_SUCCESSFUL)
>> - rtems_bdbuf_fatal (RTEMS_BDBUF_FATAL_RA_WAKE_UP);
>> - rtems_chain_append_unprotected (chain, &dd->read_ahead.node);
>> + dd->read_ahead.nr_blocks = RTEMS_DISK_READ_AHEAD_SIZE_AUTO;
>> + rtems_bdbuf_read_ahead_add_to_chain(dd);
>> @@ -2112,6 +2119,24 @@ rtems_bdbuf_read (rtems_disk_device *dd,
>> return sc;
>> +void
>> +rtems_bdbuf_peek (rtems_disk_device *dd,
>> + uint32_t nr_blocks)
>> + rtems_bdbuf_lock_cache ();
>> + if (bdbuf_cache.read_ahead_enabled && nr_blocks > 0)
>> + rtems_bdbuf_read_ahead_reset(dd);
>> + dd->read_ahead.next = block;
>> + dd->read_ahead.nr_blocks = nr_blocks;
>> + rtems_bdbuf_unlock_cache ();
>> static rtems_status_code
>> rtems_bdbuf_check_bd_and_lock_cache (rtems_bdbuf_buffer *bd, const char *kind)
>> @@ -2952,18 +2977,33 @@ rtems_bdbuf_read_ahead_task (rtems_task_argument arg)
>> if (bd != NULL)
>> - uint32_t transfer_count = dd->block_count - block;
>> + uint32_t transfer_count = dd->read_ahead.nr_blocks;
>> + uint32_t blocks_until_end_of_disk = dd->block_count - block;
>> uint32_t max_transfer_count = bdbuf_config.max_read_ahead_blocks;
>> - if (transfer_count >= max_transfer_count)
>> - transfer_count = max_transfer_count;
>> - dd->read_ahead.trigger = block + transfer_count / 2;
>> - dd->read_ahead.next = block + transfer_count;
>> - else
>> - dd->read_ahead.trigger = RTEMS_DISK_READ_AHEAD_NO_TRIGGER;
>> + if (transfer_count == RTEMS_DISK_READ_AHEAD_SIZE_AUTO) {
>> + transfer_count = blocks_until_end_of_disk;
>> + if (transfer_count >= max_transfer_count)
>> + transfer_count = max_transfer_count;
>> + dd->read_ahead.trigger = block + transfer_count / 2;
>> + dd->read_ahead.next = block + transfer_count;
>> + else
>> + dd->read_ahead.trigger = RTEMS_DISK_READ_AHEAD_NO_TRIGGER;
>> + } else {
>> + if (transfer_count > blocks_until_end_of_disk) {
>> + if (transfer_count > max_transfer_count) {
>> + ++dd->stats.read_ahead_peeks;
>> ++dd->stats.read_ahead_transfers;
>> diff --git a/cpukit/libblock/src/blkdev-print-stats.c b/cpukit/libblock/src/blkdev-print-stats.c
>> index 8edf24fd8c..539ff08157 100644
>> --- a/cpukit/libblock/src/blkdev-print-stats.c
>> +++ b/cpukit/libblock/src/blkdev-print-stats.c
>> @@ -47,6 +47,7 @@ void rtems_blkdev_print_stats(
>> " READ HITS | %" PRIu32 "\n"
>> " READ MISSES | %" PRIu32 "\n"
>> " READ AHEAD TRANSFERS | %" PRIu32 "\n"
>> + " READ AHEAD PEEKS | %" PRIu32 "\n"
>> " READ BLOCKS | %" PRIu32 "\n"
>> " READ ERRORS | %" PRIu32 "\n"
>> " WRITE TRANSFERS | %" PRIu32 "\n"
>> @@ -59,6 +60,7 @@ void rtems_blkdev_print_stats(
>> stats->read_hits,
>> stats->read_misses,
>> stats->read_ahead_transfers,
>> + stats->read_ahead_peeks,
>> stats->read_blocks,
>> stats->read_errors,
>> stats->write_transfers,
>> diff --git a/testsuites/fstests/fsdosfswrite01/init.c b/testsuites/fstests/fsdosfswrite01/init.c
>> index e5d8e5d6dd..64b43b7919 100644
>> --- a/testsuites/fstests/fsdosfswrite01/init.c
>> +++ b/testsuites/fstests/fsdosfswrite01/init.c
>> @@ -129,6 +129,7 @@ static void test_normal_file_write(
>> .read_hits = 0,
>> .read_misses = 0,
>> .read_ahead_transfers = 0,
>> + .read_ahead_peeks = 0,
>> .read_blocks = 0,
>> .read_errors = 0,
>> .write_transfers = 1,
>> @@ -139,6 +140,7 @@ static void test_normal_file_write(
>> .read_hits = 3,
>> .read_misses = 2,
>> .read_blocks = 2,
>> .read_errors = 0,
>> @@ -149,6 +151,7 @@ static void test_normal_file_write(
>> .read_hits = 3,
>> .read_misses = 3,
>> .read_blocks = 3,
>> .read_errors = 0,
>> diff --git a/testsuites/libtests/block14/block14.scn b/testsuites/libtests/block14/block14.scn
>> index 7170522579..cf5518adfd 100644
>> --- a/testsuites/libtests/block14/block14.scn
>> +++ b/testsuites/libtests/block14/block14.scn
>> @@ -6,19 +6,30 @@ action 3
>> action 4
>> action 5
>> action 6
>> +action 7
>> +action 8
>> +action 9
>> +action 10
>> +action 11
>> +action 12
>> +action 13
>> +action 14
>> +action 15
>> DEVICE STATISTICS
>> MEDIA BLOCK SIZE | 0
>> MEDIA BLOCK COUNT | 1
>> BLOCK SIZE | 2
>> - READ HITS | 2
>> - READ MISSES | 3
>> - READ AHEAD TRANSFERS | 2
>> - READ BLOCKS | 5
>> + READ HITS | 4
>> + READ MISSES | 7
>> + READ AHEAD TRANSFERS | 6
>> + READ AHEAD PEEKS | 3
>> + READ BLOCKS | 13
>> READ ERRORS | 1
>> WRITE TRANSFERS | 2
>> WRITE BLOCKS | 2
>> WRITE ERRORS | 1
>> *** END OF TEST BLOCK 14 ***
>> diff --git a/testsuites/libtests/block14/init.c b/testsuites/libtests/block14/init.c
>> index b4e73aadc9..13b7ab05ad 100644
>> --- a/testsuites/libtests/block14/init.c
>> +++ b/testsuites/libtests/block14/init.c
>> @@ -29,9 +29,9 @@
>> const char rtems_test_name[] = "BLOCK 14";
>> -#define ACTION_COUNT 7
>> +#define ACTION_COUNT 16
>> -#define BLOCK_COUNT 6
>> +#define BLOCK_COUNT 14
>> #define DISK_PATH "/disk"
>> @@ -42,50 +42,104 @@ typedef struct {
>> rtems_bdbuf_buffer **bd_ptr
>> + void (*peek)(
>> rtems_status_code expected_get_status;
>> rtems_status_code (*release)(rtems_bdbuf_buffer *bd);
>> } test_action;
>> static const test_action actions [ACTION_COUNT] = {
>> - { 0, rtems_bdbuf_read, RTEMS_SUCCESSFUL, rtems_bdbuf_release },
>> - { 1, rtems_bdbuf_read, RTEMS_SUCCESSFUL, rtems_bdbuf_release },
>> - { 2, rtems_bdbuf_read, RTEMS_SUCCESSFUL, rtems_bdbuf_release },
>> - { 4, rtems_bdbuf_get, RTEMS_SUCCESSFUL, rtems_bdbuf_sync },
>> - { 5, rtems_bdbuf_read, RTEMS_IO_ERROR, rtems_bdbuf_release },
>> - { 5, rtems_bdbuf_get, RTEMS_SUCCESSFUL, rtems_bdbuf_sync }
>> + /* normal read ahead */
>> + { 0, rtems_bdbuf_read, NULL, RTEMS_SUCCESSFUL, rtems_bdbuf_release },
>> + { 1, rtems_bdbuf_read, NULL, RTEMS_SUCCESSFUL, rtems_bdbuf_release },
>> + { 2, rtems_bdbuf_read, NULL, RTEMS_SUCCESSFUL, rtems_bdbuf_release },
>> + /* re-read a cached block */
>> + /* cause some writes */
>> + { 4, rtems_bdbuf_get, NULL, RTEMS_SUCCESSFUL, rtems_bdbuf_sync },
>> + { 5, rtems_bdbuf_read, NULL, RTEMS_IO_ERROR, rtems_bdbuf_release },
>> + { 5, rtems_bdbuf_get, NULL, RTEMS_SUCCESSFUL, rtems_bdbuf_sync },
>> + /* interrupt normal read ahead with a peek */
>> + { 9, rtems_bdbuf_read, NULL, RTEMS_SUCCESSFUL, rtems_bdbuf_release },
>> + { 13, NULL, rtems_bdbuf_peek, 0, NULL },
>> + { 10, rtems_bdbuf_read, NULL, RTEMS_SUCCESSFUL, rtems_bdbuf_release },
>> + { 11, rtems_bdbuf_read, NULL, RTEMS_SUCCESSFUL, rtems_bdbuf_release },
>> + { 12, rtems_bdbuf_read, NULL, RTEMS_SUCCESSFUL, rtems_bdbuf_release },
>> + /* peek with hit */
>> + { 6, NULL, rtems_bdbuf_peek, 0, NULL },
>> + { 6, rtems_bdbuf_read, NULL, RTEMS_SUCCESSFUL, rtems_bdbuf_release },
>> + /* (wrong) peek with reading different block */
>> + { 8, NULL, rtems_bdbuf_peek, 0, NULL },
>> + { 7, rtems_bdbuf_read, NULL, RTEMS_SUCCESSFUL, rtems_bdbuf_release },
>> -#define STATS(a, b, c, d, e, f, g, h) \
>> +#define STATS(a, b, c, d, e, f, g, h, i) \
>> .read_hits = a, \
>> .read_misses = b, \
>> .read_ahead_transfers = c, \
>> - .read_blocks = d, \
>> - .read_errors = e, \
>> - .write_transfers = f, \
>> - .write_blocks = g, \
>> - .write_errors = h \
>> + .read_ahead_peeks = d, \
>> + .read_blocks = e, \
>> + .read_errors = f, \
>> + .write_transfers = g, \
>> + .write_blocks = h, \
>> + .write_errors = i \
>> static const rtems_blkdev_stats expected_stats [ACTION_COUNT] = {
>> - STATS(0, 1, 0, 1, 0, 0, 0, 0),
>> - STATS(0, 2, 1, 3, 0, 0, 0, 0),
>> - STATS(1, 2, 2, 4, 0, 0, 0, 0),
>> - STATS(2, 2, 2, 4, 0, 0, 0, 0),
>> - STATS(2, 2, 2, 4, 0, 1, 1, 0),
>> - STATS(2, 3, 2, 5, 1, 1, 1, 0),
>> - STATS(2, 3, 2, 5, 1, 2, 2, 1)
>> + STATS(0, 1, 0, 0, 1, 0, 0, 0, 0),
>> + STATS(0, 2, 1, 0, 3, 0, 0, 0, 0),
>> + STATS(1, 2, 2, 0, 4, 0, 0, 0, 0),
>> + STATS(2, 2, 2, 0, 4, 0, 0, 0, 0),
>> + STATS(2, 2, 2, 0, 4, 0, 1, 1, 0),
>> + STATS(2, 3, 2, 0, 5, 1, 1, 1, 0),
>> + STATS(2, 3, 2, 0, 5, 1, 2, 2, 1),
>> + STATS(2, 4, 2, 0, 6, 1, 2, 2, 1),
>> + STATS(2, 4, 3, 1, 7, 1, 2, 2, 1),
>> + STATS(2, 5, 3, 1, 8, 1, 2, 2, 1),
>> + STATS(2, 6, 4, 1, 10, 1, 2, 2, 1),
>> + STATS(3, 6, 4, 1, 10, 1, 2, 2, 1),
>> + STATS(3, 6, 5, 2, 11, 1, 2, 2, 1),
>> + STATS(4, 6, 5, 2, 11, 1, 2, 2, 1),
>> + STATS(4, 6, 6, 3, 12, 1, 2, 2, 1),
>> + STATS(4, 7, 6, 3, 13, 1, 2, 2, 1),
>> static const int expected_block_access_counts [ACTION_COUNT] [BLOCK_COUNT] = {
>> - { 1, 0, 0, 0, 0, 0 },
>> - { 1, 1, 1, 0, 0, 0 },
>> - { 1, 1, 1, 1, 0, 0 },
>> - { 1, 1, 1, 1, 1, 0 },
>> - { 1, 1, 1, 1, 1, 1 },
>> - { 1, 1, 1, 1, 1, 2 }
>> + { 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 },
>> + { 1, 1, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 },
>> + { 1, 1, 1, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 },
>> + { 1, 1, 1, 1, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0 },
>> + { 1, 1, 1, 1, 1, 1, 0, 0, 0, 0, 0, 0, 0, 0 },
>> + { 1, 1, 1, 1, 1, 2, 0, 0, 0, 0, 0, 0, 0, 0 },
>> + { 1, 1, 1, 1, 1, 2, 0, 0, 0, 1, 0, 0, 0, 0 },
>> + { 1, 1, 1, 1, 1, 2, 0, 0, 0, 1, 0, 0, 0, 1 },
>> + { 1, 1, 1, 1, 1, 2, 0, 0, 0, 1, 1, 0, 0, 1 },
>> + { 1, 1, 1, 1, 1, 2, 0, 0, 0, 1, 1, 1, 1, 1 },
>> + { 1, 1, 1, 1, 1, 2, 1, 0, 0, 1, 1, 1, 1, 1 },
>> + { 1, 1, 1, 1, 1, 2, 1, 0, 1, 1, 1, 1, 1, 1 },
>> + { 1, 1, 1, 1, 1, 2, 1, 1, 1, 1, 1, 1, 1, 1 },
>> static int block_access_counts [BLOCK_COUNT];
>> @@ -132,10 +186,16 @@ static void test_actions(rtems_disk_device *dd)
>> printf("action %i\n", i);
>> - sc = (*action->get)(dd, action->block, &bd);
>> - rtems_test_assert(sc == action->expected_get_status);
>> + if (action->get != NULL) {
>> + sc = (*action->get)(dd, action->block, &bd);
>> + rtems_test_assert(sc == action->expected_get_status);
>> + if (action->peek != NULL) {
>> + (*action->peek)(dd, action->block, 1);
>> - if (sc == RTEMS_SUCCESSFUL) {
>> + if (sc == RTEMS_SUCCESSFUL && action->release != NULL) {
>> sc = (*action->release)(bd);
>> rtems_test_assert(sc == RTEMS_SUCCESSFUL);
>> 2.26.2
>> devel mailing list
>> devel at rtems.org
embedded brains GmbH
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 18
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
