[PATCH v3 1/3] rtems-debugger: Fixed 32bit pointers
Joel Sherrill
joel at rtems.org
Mon Mar 22 21:06:14 UTC 2021
On Mon, Mar 22, 2021, 3:54 PM Chris Johns <chrisj at rtems.org> wrote:
> On 23/3/21 4:58 am, Joel Sherrill wrote:
> > On Mon, Mar 22, 2021 at 12:54 PM Joel Sherrill <joel at rtems.org
> > <mailto:joel at rtems.org>> wrote:
> > I posted to the gdb mailing list and this is the response:
> > "If the inferior is using 64-bit addresses, then the remote protocol
> will
> > also use 64-bit addresses. If we have a 32-bit inferior running on
> > aarch64 hardware, we'll have 32-bit addresses over the remote
> protocol
> > as well.
> > Even when we're using 64-bit addresses, the remote protocol may not
> pad
> > it with zeroes to make it 64-bit, but it should still be handled as
> 64-bit."
> > Unfortunately, I think this means that everywhere the debugger code
> > uses a decode (is there an encode?) uint to decode an address that
> > code needs to change to decode an address (e.g. uintptr) where one
> is
> > expected in the protocol. And all target addresses in the debugger
> need
> > to change to uintptr_t.
> > Luis from gdb just followed up and suggested we always treat it as
> > 64-bit and cast to 32-bits. I think uintptr_t is the right answer but I
> > wanted to pass that along.
> Thanks and yes this makes sense. Great idea to ask over at gdb.
I've chatted with Steven privately to explain this. He's going to add a
decode address function and then pull the thread from there. I think that
will probably be enough to get this right combined with testing on the BBB.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210322/6fc670a7/attachment.html>
