GSoC Prerequisite Task
Ahamed Husni
ahamedhusni73 at gmail.com
Tue Mar 23 10:10:07 UTC 2021
Thank you sir.
Usually, I remember to ask students to just email it directly to me.
I sent the patch couple of times to the mailing list but I didn't get any
responses.
So I added you separately thinking that the earlier mails didn't get
delivered :)
Sorry about that.
Please add your info to
> https://devel.rtems.org/wiki/GSoC/2021#StudentsProposals
> and start to investigate which open projects you might like to
> consider. You will need to engage on the devel mailing list with the
> potential mentors about those projects, as some of the projects may be
> no longer available or suitable, and in general the projects need to
> be scoped appropriately. This engagement is best done in a separate
> email thread dedicated to the proposed area(s) you want to investigate.
I'll do that. I'm interested in Beagle BSP projects. I'll start a new email
thread for that with
the subject "GSoC Project - Beagle BSP Projects".
-- Husni Faiz
On Mon, Mar 22, 2021 at 9:51 PM Gedare Bloom <gedare at rtems.org> wrote:
> On Mon, Mar 22, 2021 at 10:11 AM Ahamed Husni <ahamedhusni73 at gmail.com>
> wrote:
>> Dear sir,
>> Is this proof of work acceptable?
> Yes.
>> On Mon, Mar 22, 2021 at 11:56 AM Ahamed Husni <ahamedhusni73 at gmail.com>
>> wrote:
>>> HI,
>>> I'm having trouble sending the screenshots.
>>> I get an email with the subject "Your message to devel awaits moderator
>>> approval".
>> I attached the screenshot for both the programs output and the test
>>> output.
>>> That might have exceeded the maximum message size(256KB).
>>> I'll attach only the program output to this thread.
>>> Thanks,
>>> Husni.
>>> [image: hello_out.png]
>>> On Mon, Mar 22, 2021 at 11:38 AM Ahamed Husni <ahamedhusni73 at gmail.com>
>>> wrote:
>>>> Hi all,
>>>> This is the modified hello program. I'll attach the screenshots in
>>>> another email.
>>>> From 794d291f61c70dfcefb6b566e2a6a4af0fb801a5 Mon Sep 17 00:00:00 2001
>>>> From: Husni Faiz <ahamedhusni73 at gmail.com>
>>>> Date: Mon, 22 Mar 2021 01:18:25 +0530
>>>> Subject: [PATCH] GSoC Task
>>>> Modified the hello program to meet the requirement.
>>>> testsuites/samples/hello/init.c | 4 +++-
>>>> 1 file changed, 3 insertions(+), 1 deletion(-)
>>>> diff --git a/testsuites/samples/hello/init.c
>>>> b/testsuites/samples/hello/init.c
>>>> index 34ded37c55..b215b1fcf9 100644
>>>> --- a/testsuites/samples/hello/init.c
>>>> +++ b/testsuites/samples/hello/init.c
>>>> @@ -22,7 +22,9 @@ static rtems_task Init(
>>>> rtems_print_printer_fprintf_putc(&rtems_test_printer);
>>>> TEST_BEGIN();
>>>> - printf( "Hello World\n" );
>>>> + printf( "Hello Embedded World\n" );
>>>> + printf( "Welcome to GSoC 202!\n" );
>>>> + printf( "I'm Husni\n" );
>>>> TEST_END();
>>>> rtems_test_exit( 0 );
>>>> 2.17.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210323/a7962853/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210323/a7962853/attachment-0001.png>
