Policy for return by reference values in error cases
Sebastian Huber
Tue Mar 23 17:30:08 UTC 2021
Hello,
for the RTEMS pre-qualification project I review currently most parts of
the Classic API. It seems we have an unwritten rule that directives
should not write to variables referenced by directive parameters if an
error occurs. Examples:
* rtems_task_mode(previous_mode)
* rtems_task_set_priority(previous_priority)
* rtems_message_queue_receive(message_size)
* rtems_event_receive(received_events)
We should think about changing this rule to instead return "safe" values
in error conditions. For example, lets have an application bug I
encountered this year. The code originally looked like this:
#define APP_TIMEOUT RTEMS_NO_TIMEOUT
rtems_event_set events;
(void) rtems_event_receive(
RTEMS_ALL_EVENTS,
RTEMS_EVENT_ANY | RTEMS_WAIT,
APP_TIMEOUT,
&events
if (event & X) != 0) {
Ok, you should check the return value, but ...
Something didn't go well and someone changed APP_TIMEOUT:
#define APP_TIMEOUT 1000
Now, sometimes the rtems_event_receive() timed out and the application
worked with events produced by the stack frame and not
rtems_event_receive(). In the case of rtems_message_queue_receive() it
would be the message size.
In order to let broken applications fail a bit more gracefully, it would
help to set the events and the message size to zero if the directive
returns with an error. The modes could be set to the defaults, the
priority to some invalid value, etc.
What do you think?
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
