[PATCH] bsps: Removed INI files using outdated options
Joel Sherrill
joel at rtems.org
Tue Mar 23 18:29:50 UTC 2021
Better would be
sparc bsps: Remove INI files using SIS in GDB
On Tue, Mar 23, 2021 at 1:13 PM Ryan Long <ryan.long at oarcorp.com> wrote:
> Removed the INI files that use the "target sim" option in gdb
> since this is no longer supported.
This needs to be more accurate.
Specifically, the sis sparc simulator in gdb is no longer used with RTEMS
and
we use a newer version of SIS built separately.
This ONLY impacts the SPARC.
--joel
> Closes #4355
> tester/rtems/testing/bsps/erc32.ini | 41
> tester/rtems/testing/bsps/leon2.ini | 41
> tester/rtems/testing/bsps/leon3.ini | 41
> 3 files changed, 123 deletions(-)
> delete mode 100644 tester/rtems/testing/bsps/erc32.ini
> delete mode 100644 tester/rtems/testing/bsps/leon2.ini
> delete mode 100644 tester/rtems/testing/bsps/leon3.ini
> diff --git a/tester/rtems/testing/bsps/erc32.ini
> b/tester/rtems/testing/bsps/erc32.ini
> deleted file mode 100644
> index 7911a2f..0000000
> --- a/tester/rtems/testing/bsps/erc32.ini
> +++ /dev/null
> @@ -1,41 +0,0 @@
> -# RTEMS Tools Project (http://www.rtems.org/)
> -# Copyright 2015 On-Line Applications Research Corporation (OAR).
> -# All rights reserved.
> -# This file is part of the RTEMS Tools package in 'rtems-tools'.
> -# Redistribution and use in source and binary forms, with or without
> -# modification, are permitted provided that the following conditions are
> met:
> -# 1. Redistributions of source code must retain the above copyright
> notice,
> -# this list of conditions and the following disclaimer.
> -# 2. Redistributions in binary form must reproduce the above copyright
> notice,
> -# this list of conditions and the following disclaimer in the
> documentation
> -# and/or other materials provided with the distribution.
> -# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS
> IS"
> -# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
> THE
> -# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> -# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS
> BE
> -# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> -# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> -# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> -# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> -# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> -# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
> THE
> -# POSSIBILITY OF SUCH DAMAGE.
> -# The erc32 BSP
> -[erc32]
> -bsp = erc32
> -arch = sparc
> -tester = %{_rtscripts}/gdb.cfg
> -gdb_script = bsp_gdb_script
> -bsp_gdb_script = target sim
> - load
> - run
> diff --git a/tester/rtems/testing/bsps/leon2.ini
> b/tester/rtems/testing/bsps/leon2.ini
> index 77fed49..0000000
> --- a/tester/rtems/testing/bsps/leon2.ini
> +++ /dev/null
> @@ -1,41 +0,0 @@
> met:
> notice,
> notice,
> documentation
> IS"
> THE
> PURPOSE
> BE
> THE
> -# The leon2 BSP
> -[leon2]
> -bsp = leon2
> -arch = sparc
> -bsp_gdb_script = target sim -leon2
> - load
> - run
> diff --git a/tester/rtems/testing/bsps/leon3.ini
> b/tester/rtems/testing/bsps/leon3.ini
> index 74eafb7..0000000
> --- a/tester/rtems/testing/bsps/leon3.ini
> +++ /dev/null
> @@ -1,41 +0,0 @@
> met:
> notice,
> notice,
> documentation
> IS"
> THE
> PURPOSE
> BE
> THE
> -# The leon3 BSP
> -[leon3]
> -bsp = leon3
> -arch = sparc
> -bsp_gdb_script = target sim -leon3
> - load
> - run
> 1.8.3.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210323/27f6d6b0/attachment-0001.html>
