Question regarding an open project and documentation enhancement
Ayushman Mishra
ayushvidushi01 at gmail.com
Tue Mar 23 18:45:16 UTC 2021
I have send patches regarding addition of FAQ page in user/quick-start
section of docs . Here I had to make extra links in 7.5
autoconf-migrations ,1.2 features,3.1 project support and corrected
the link in https://docs.rtems.org/branches/master/user/bld/index.html#commands
. In 2nd patch I moved questions of
https://docs.rtems.org/branches/master/user/support/contrib.html#common-questions-and-answers
from 3.3 Contributing section to FAQ page.
On Thu, Mar 18, 2021 at 9:46 PM Gedare Bloom <gedare at rtems.org> wrote:
> On Thu, Mar 18, 2021 at 10:08 AM Ayushman Mishra
> <ayushvidushi01 at gmail.com> wrote:
> > Sorry for the delay (actually I was little busy due to my semester
> > examination) and extremely sorry for my previous behaviour
> > I have created a frequently asked questions (FAQ) page under
> > quick-start section in user guide according to the ticket
> > https://devel.rtems.org/ticket/3958 . I have attached an image of how
> > the page looks after build up, and will send a patch for it as soon as
> > possible ( currently some links are not working correctly) . Most of
> > the questions are from https://devel.rtems.org/wiki/TBR/Website/FAQ
> > but I am also writing a few questions of my own (like about .waf and
> > autoconf build up)
> Great. Maybe, start with the patch to add the new FAQ section to the
> docs, and a second patch to migrate the contents from the Trac, and
> then a third patch to add some more questions.
> > Also I wanted to take https://devel.rtems.org/ticket/4334 (Replace
> > Mongoose with Civitweb) as a GSOC project as I have huge interest in
> > networking related projects but lack experience in it. I would be very
> > grateful to know more about this project.
> This is a good project also. Note there is a typo in the ticket title,
> the project is called Civetweb; I fixed the ticket typos. For this
> project, during the proposal preparation phase you should get RTEMS
> working with a networking stack and able to run the existing mongoose
> webserver (mghttpd) would be a very good start. I would suggest you
> start a new thread to discuss this project, and to ask for more
> guidance there.
> Gedare
> > On Tue, Mar 2, 2021 at 10:28 PM Gedare Bloom <gedare at rtems.org> wrote:
> > > On Tue, Mar 2, 2021 at 9:11 AM Joel Sherrill <joel at rtems.org> wrote:
> > > > On Tue, Mar 2, 2021 at 9:08 AM Ayushman Mishra <ayushvidushi01 at gmail.com> wrote:
> > > >> 1. Hello everyone, I went through open ticket "Code Formatting and
> > > >> Style Check for RTEMS score" (https://devel.rtems.org/ticket/3860) as
> > > >> a possible GSOC project and discussion thread on it
> > > >> https://lists.rtems.org/pipermail/devel/2020-February/057246.html,
> > > >> https://lists.rtems.org/pipermail/devel/2020-February/057057.html .
> > > >> But most of the threads on this project are almost a year old , I
> > > >> wanted to know has there been any recent development on this project
> > > >> and is there any specific tool developed/under-development for it. I
> > > >> would be grateful to connect with mentor of this project in-order to
> > > >> know more about the complexity involved and resources available for
> > > >> it.
> > > > As Sebastian said, it hasn't had any recent work but still needs attention.
> > > > I think we have a first candidate style description and tool but it has not
> > > > been checked against the code to see what differences exist between the
> > > > RTEMS style and the generated style. These differences could be because
> > > > the formatting specification to the tool needs tweaking, the input RTEMS code
> > > > didn't follow the rules before, or we could need to consider changing our style
> > > > rules.
> > > > The score/src directory is thought to be the one of the ones which would
> > > > follow the RTEMS style most consistently. Focusing there should help
> > > > establish a baseline style, scripts, and change recommendations.
> > > > Style adherence also has to be accounted for as part of the patch review
> > > > and git commit process. Hopefully it can be automated.
> > > > Taking a broad view of this could be a good GSoC project. At least I
> > > > think there is enough programming in it to count as one.
> > > Yes, this can be a GSoC project.
> > > >> 2. Also I checked the issue #3958 https://devel.rtems.org/ticket/3958
> > > >> , fixed some of the broken links of FAQ page but few of the answers I
> > > >> got were from sites other than user guide. I would like to create a
> > > >> separate FAQ page in user-guide having some of answers available there
> > > >> only and some available as links.
> > > > As a general rule, a lot of what is in the Wiki should be in regular documentation
> > > > at docs.rtems.org. A lot has been converted, some in the wiki is already in the
> > > > documentation but has not been checked for consistency in the conversion.
> > > > This is not a GSoC task by the program rules but if you have spotted something
> > > > that is in both, we would like to resolve it. File a ticket saying wiki page X and
> > > > documentation section Y are the same and that you double checked it. Then
> > > > someone with permissions can delete the page. This really is appreciated. I
> > > > have done a LOT of pages but there are more to go.
> > > > For example, I think almost all of the patch process and git instructions have
> > > > been added to the docs but are still in the Wiki. There may be a section that
> > > > remains to be converted but it needs review, missing content added to the docs,
> > > > and then deletion. Deletion involves updating links. Tedious but important.
> > > +1
> > > And if you want to create a FAQ in the User Guide, that would be fine,
> > > you can learn how to build the docs and submit patches. As Joel said,
> > > that kind of work is not allowed under GSoC but it is good for your
> > > knowledge and technical development.
> > > > --joel
> > > >> Ayushman
> > > >> _______________________________________________
> > > >> devel mailing list
> > > >> devel at rtems.org
> > > >> http://lists.rtems.org/mailman/listinfo/devel
> > > > devel mailing list
> > > > devel at rtems.org
