[PATCH] bsps: Removed INI files using outdated options
Ryan Long
ryan.long at oarcorp.com
Tue Mar 23 19:18:05 UTC 2021
There are replacements to run these on sis. They just have -sis.ini on the end of them.
-----Original Message-----
Sent: Tuesday, March 23, 2021 2:07 PM
To: Joel Sherrill <joel at rtems.org>
Cc: Ryan Long <ryan.long at oarcorp.com>; rtems-devel at rtems.org <devel at rtems.org>
Subject: Re: [PATCH] bsps: Removed INI files using outdated options
> Better would be
> sparc bsps: Remove INI files using SIS in GDB
actually, bsps/sparc is preferred.
I don't know that we have this documented though.
> On Tue, Mar 23, 2021 at 1:13 PM Ryan Long <ryan.long at oarcorp.com> wrote:
>> Removed the INI files that use the "target sim" option in gdb since
>> this is no longer supported.
> This needs to be more accurate.
> Specifically, the sis sparc simulator in gdb is no longer used with
> RTEMS and we use a newer version of SIS built separately.
> This ONLY impacts the SPARC.
> --joel
>> Closes #4355
>> tester/rtems/testing/bsps/erc32.ini | 41
>> tester/rtems/testing/bsps/leon2.ini | 41
>> tester/rtems/testing/bsps/leon3.ini | 41
>> 3 files changed, 123 deletions(-)
>> delete mode 100644 tester/rtems/testing/bsps/erc32.ini
>> delete mode 100644 tester/rtems/testing/bsps/leon2.ini
>> delete mode 100644 tester/rtems/testing/bsps/leon3.ini
i haven't looked, but are there replacements (to run these on sis directly?)
>> diff --git a/tester/rtems/testing/bsps/erc32.ini
>> b/tester/rtems/testing/bsps/erc32.ini
>> deleted file mode 100644
>> index 7911a2f..0000000
>> --- a/tester/rtems/testing/bsps/erc32.ini
>> +++ /dev/null
>> @@ -1,41 +0,0 @@
>> -# RTEMS Tools Project (http://www.rtems.org/) -# Copyright 2015
>> On-Line Applications Research Corporation (OAR).
>> -# All rights reserved.
>> -# This file is part of the RTEMS Tools package in 'rtems-tools'.
>> -# Redistribution and use in source and binary forms, with or without
>> -# modification, are permitted provided that the following conditions are met:
>> -# 1. Redistributions of source code must retain the above copyright
>> notice, -# this list of conditions and the following disclaimer.
>> -# 2. Redistributions in binary form must reproduce the above
>> copyright notice, -# this list of conditions and the following
>> disclaimer in the documentation -# and/or other materials provided with the distribution.
>> -# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
>> -# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
>> TO, THE -# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
>> PARTICULAR PURPOSE -# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
>> HOLDER OR CONTRIBUTORS BE -# LIABLE FOR ANY DIRECT, INDIRECT,
>> INCIDENTAL, SPECIAL, EXEMPLARY, OR -# CONSEQUENTIAL DAMAGES
>> (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF -# SUBSTITUTE GOODS OR
>> SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS -# INTERRUPTION)
>> HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN -#
>> CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>> OTHERWISE) -# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE -# POSSIBILITY OF SUCH DAMAGE.
>> -# The erc32 BSP
>> -[erc32]
>> -bsp = erc32
>> -arch = sparc
>> -tester = %{_rtscripts}/gdb.cfg
>> -gdb_script = bsp_gdb_script
>> -bsp_gdb_script = target sim
>> - load
>> - run
>> diff --git a/tester/rtems/testing/bsps/leon2.ini
>> b/tester/rtems/testing/bsps/leon2.ini
>> index 77fed49..0000000
>> --- a/tester/rtems/testing/bsps/leon2.ini
>> +++ /dev/null
>> @@ -1,41 +0,0 @@
>> -# The leon2 BSP
>> -[leon2]
>> -bsp = leon2
>> -arch = sparc
>> -bsp_gdb_script = target sim -leon2
>> - load
>> - run
>> diff --git a/tester/rtems/testing/bsps/leon3.ini
>> b/tester/rtems/testing/bsps/leon3.ini
>> index 74eafb7..0000000
>> --- a/tester/rtems/testing/bsps/leon3.ini
>> +++ /dev/null
>> @@ -1,41 +0,0 @@
>> -# The leon3 BSP
>> -[leon3]
>> -bsp = leon3
>> -arch = sparc
>> -bsp_gdb_script = target sim -leon3
>> - load
>> - run
>> 1.8.3.1
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
